STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Running a Sidwinder RTX with a tune. Trail ride only. Looking to change gears to get a bigger top gear to take some of the turn out of the chain. Does anyone have a gear/chain chart for these chain cases?
Turboflash
- Mar 18, 2019
- Southern MN
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
You can put a 22 top gear with the stock chain.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Yes,it may take two to help hold both gears and chain,as you have to fit them on togeather,takes a little bit first time,but they will fit on.You can put a 22 top gear with the stock chain.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
That chart does not show 41/22 but it does fit with stock chain.
I'm running 24/48 at the moment. It's good for 120ish GPS. I also like that the chain won't rub the post with this combo.Running a Sidwinder RTX with a tune. Trail ride only. Looking to change gears to get a bigger top gear to take some of the turn out of the chain. Does anyone have a gear/chain chart for these chain cases?
Turboflash
- Mar 18, 2019
- Southern MN
Running 132 GPS @ w 21/38 @ 8800 RPM. 280 HP tune at 1/2 mile not best surface.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
24/41....on my Turbo Viper, still pretty trailable, take no prisoners!
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I am not concerned with top speed. I dont spend any time up there. I want to to pull like a freight train to over 100 mph.
I also think that taking some turn out of the chain might help some with top gear bushing wear.
Byam
You will like 24/48 if you can put it down!
I had this gearing in my turbo viper
I wish Yamaha or Cat sold a 15wide 25 top gear.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
I did nothing but gain on all when I went with 22T verses the 21T. I first tried the 22 after my first tune but I did run the tune with the 21T first. Just smoother and faster with my set up back then and now, with the Max Spool 16/3 bar/BOV.
Maybe a different story if I was running on ice and hooking up hard out of the hole and running shorter distances.
Big_Phil
- Feb 5, 2014
- Sidewinder RTX LE
I don't think it will help with top bushing wear. My RTX has over 11000 kms on the stock 21 top gear. All with the hurricane 270r
Sure would like to see it. Is the grey coating on it yet? If not maybe we are all being premature in changing them?I don't think it will help with top bushing wear. My RTX has over 11000 kms on the stock 21 top gear. All with the hurricane 270r
Big_Phil
- Feb 5, 2014
- Sidewinder RTX LE
Ill take a pic and post it next week when I tear the sled down for pre season maintenance. It was good last time I was in there @9000kms or so. Im planning on getting a new top gear and possibly chain as well this year. I do about 5000kms a season and don't want a failure.
- 13K
