mpaine
- Mar 28, 2014
I've been looking around trying to find if anyone has swapped a sidewinder motor into a axys chassis pro rmk. Like people were doing years ago with the nypro.
It's been in the back of my mind for a couple years now and I'm starting to think it's going to become a project sooner than later.
I would think it will fit. I'm having a hard time finding any really specs on the sidewinder motors dimensions or weight. I know I can do the fab work and get it in just a little reassurance on dimensions would be nice before I start buying parts.
Also I'm thinking I would try and use an apex chaincase with reverse since it's one of the only bolt on chaincase I've seen.
Looking forward to some input!
What would be the advantage to this huge amount of work?I've been looking around trying to find if anyone has swapped a sidewinder motor into a axys chassis pro rmk. Like people were doing years ago with the nypro.
You'd be better off finding a 2017 Winder mountain and buying the Alpha skid which is the best part of Cat's mountain sleds.
mpaine
- Mar 28, 2014
They are just still heavy #*$&@ sleds. Right now I have a supercharger nytro with 163 m8 skid, front end kit plus all the little upgrades. It's a blast and I love the reliability but its heavy. Still takes two hands to lift the back off the ground. Pro rmk can be lifted with one hand easily.
There Is close to 100lb deference between the winder and pro. So if I can get winder power and reliability in a pro I see no reason not to.
Plus it would be cool to do!
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
I love the idea. I wished Polaris would contract Yamaha to sling the 1049 in their XC.
Keep us posted.
MS
Keep us posted.
MS
The weight is the engine.They are just still heavy #*$&@ sleds. Right now I have a supercharger nytro with 163 m8 skid, front end kit plus all the little upgrades. It's a blast and I love the reliability but its heavy. Still takes two hands to lift the back off the ground. Pro rmk can be lifted with one hand easily.
I haven't seen a Sidewinder engine in an RMK, but there is a guy that put an RX1 engine in one, so it should be doable.
mpaine
- Mar 28, 2014
I've seen the rx1, nytro and apex motors in the older rmk's. But in the new axys chassis I havnt seen any swaps yet
mpaine
- Mar 28, 2014
The nytro motor only weighs 10 lbs more than the older pro800 motor. The new 850 motor is 8 lbs heavier than the 800. So depending on how much the winder motor weighs it might not be much over the 850The weight is the engine.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
I would think by the time you were done the RMK would gain a lot of weight and be close to where you are now.
mpaine
- Mar 28, 2014
That's why I'm trying to find engine weight of the sidewinder first. So I can debate if it's worth itI would think by the time you were done the RMK would gain a lot of weight and be close to where you are now.
mpaine
- Mar 28, 2014
There is a 128lb difference between the sidewinder and the pro both 163..
I dont see why I wouldn't be able to do the swap with some lightweight parts and still be close to the stock weight on the pro.
That can't be right. The 800 twin polaris has to be more than 10 lbs lighter than that four stroke triple.
mpaine
- Mar 28, 2014
I cant find it right now. But I remember seeing them both on a scale a few years back when I was thinking about making a nypro. It was such a small difference that you could cut the weight somewhere else and end up with the same stock weight pretty easilyThat can't be right. The 800 twin polaris has to be more than 10 lbs lighter than that four stroke triple.
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
I would sure think so too. 10lbs?!?!
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
plus a turbo and pipe?
