sidewinder oil drain plug
thunderbolt
ontario, canada
Anybody gave any thought to using a hole saw and putting a 1 inch hole directly below the plug so you can access it without out trying to squeeze a wrench in or remove the muffler , like really such a simple fix wouldn't you say and put a rubber plug in there to keep the snow out
Look up @ROCKERDAN 's build thread he has a great write up on making panel removable. Hole saw is only good for oil drain but panel removal is good for all the maintenance.
Before and after
Lots of roomnow
