Gman25
- Dec 11, 2019
- ottawa
- 2018 sidewinder ltx
1999 srx 70
1993 vmax 750
Hey guys i writing this from the bar in hopes i can get a list of parts to order before i rip sled apart.
Was riding at 100 k and no more fwd will go into reverse no issue but once selecting fwd major grinding noise!!
Do i need a new uppere gear and reverse gear? thx in advance!
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
You really have to open it up and see what is what. You will need a new top gear and reverse gear for sure. Shift pads will likely be gone as well.
Turboflash
- Mar 18, 2019
- Southern MN
Chain? 16 oz. (not 12 oz like manual calls for) of a good synthetic chain lube.
GodSpeedSWE
Imo you need a minimum of these parts:
Upper gear
Oil
Orange pads for the shiftfork (likley broken)
New lockingring for outgoing shaft.
Mods can be done to prevent this.
Upper gear
Oil
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Upper gear
Oil
I had an issue last ride of the year where my SW was not going into forward from reverse and then no forward or reverse .Hey guys i writing this from the bar in hopes i can get a list of parts to order before i rip sled apart.
Cycled it on and off a couple times , and got forward working again .
I was told to ride it but don't try to put it into reverse .Was all good for that last ride , and then took it to the dealer for warranty work on chaincase but they couldn't find a problem , and it worked fine .
Just to be safe they replaced the reverse actuator and top gear under warranty , and no further problems .
YukonMP
- Dec 25, 2014
- Yukon Territory
It has been five hours, if you are still in the bar call a cab.
Gman25
- Dec 11, 2019
- ottawa
1999 srx 70
1993 vmax 750
Hey fellas thx i am tearing it apart this am
I will put a yamaha order in this morning should have it by wed.
Godspeedswe mentioned some mods to prevent this
What are you guys doing? i will plan on that.
Also on reasembly what method do you guys prefer for reverse actuator install? i used the service manual technique but have read different methods for this.
I was seriously thinking of a reverse delete but this things are way too heavy and i am too old and fat to be slinging sleds around!
Thanks for replies greatly appreciated
GodSpeedSWE
I put an aditional shim behind the upper sprocket to eliminate the huge axial play. A standard shim need to be skimmed down about 0.4mm to fit. Gives better engagement and 100% straight chain. Some people also change the bushing to a SKF version.
Also spotweld both bolts on the tentioner since its a common point of faliure.
Gman25
- Dec 11, 2019
- ottawa
1999 srx 70
1993 vmax 750
Gman25
- Dec 11, 2019
- ottawa
1999 srx 70
1993 vmax 750
Ok so you now have a stock shim behind upper gear plus the shim that has 0.4 mm removed from it?
How did you remove the 0.4 mm from this shim?
Turboflash
- Mar 18, 2019
- Southern MN
What are dimensions for shim you ended up using? Obviously 1" ID. What are OD and thickness?I put an aditional shim behind the upper sprocket to eliminate the huge axial play. A standard shim need to be skimmed down about 0.4mm to fit. Gives better engagement and 100% straight chain. Some people also change the bushing to a SKF version.
Thanks!
GodSpeedSWE
AC 2602-339
Says 1.00x1.562x0.062 on the bag.
EDIT: The need for thickness of the shim may vary from sled to sled. We did use a magnetic grindingtable at a machine shop. Fixates the washer with magnetic force. It can be used to skim of to very tight tolerances.
Gman25
- Dec 11, 2019
- ottawa
1999 srx 70
1993 vmax 750
AC 2602-339
Gman25
- Dec 11, 2019
- ottawa
1999 srx 70
1993 vmax 750
Ok so you had stock shim plus the one you modified?
How much float or freeplay was on top gear when you finished? Any or was it pretty tolight between c-clips?
Thx again
Thx again
GodSpeedSWE
Thx again
Correct, 1+1 the inside, 1 on the outside.
Made mine a bit to tight, could not feel any play but the locking ring did turn free and easy. So I guess it was pretty spot on and I did skim 0.3. If i did it again I would like 0.1 in play.
- 32K
