WINDER1987
I believe so I stole it from FacebookAt the Toronto sled show I believe correct?
Nate68
- Jan 14, 2015
- Yamaha Sidewinder L-TX
Kevin
Looks Awesome!View attachment 131860 View attachment 131861 Was finally able to get mine done after a long wait for Templates.
WINDER1987
My sled is at my fathers on the trailer and I do not have a garage at my house yet. Would it be ok to take the panels off and install it at my house with the panels off the sled or is this a bad idea trying to get the lines and decals from panel to panel to line up? Has anyone done there's this way with perfect success? Thanks
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
depends what area you are doing.....I did much of my SW and much of my CAT wrap inside house, but certain areas you will obviously have to have plastics on sled to do, and line up...IE: instrument panel which runs along side of fuel tank up to the heated seat switch. And the side panels where it slides down into that lowest panel, will likely get some graphics and need to line up too. You can take hood, and side panels into house, and line them up inside as you can see where they would come together...the rest is tougher, as you need sled put together.
Dan
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
I feel it would depend how ocd/anal you are and how intricate the graphics are on the wrap
sabrecat
Vendor
- Nov 7, 2013
Seen this sled yesterday at the Novi Snow show in MI. Really sharp!View attachment 131661 Not mine but pretty sweet wrap
PowderFalcon
Pinnin' it!
For the guys who installed wraps... what is the best practice for removing the factory graphics off the sled?
WINDER1987
Super easy just did my hood and side panels get a lil chizler off amazon there cheap and a heat gun and warm the vinyl up but keep the eBay gun moving and pull it off every one of mine came off in a whole piece with no residue left behind
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Hair blower, i dont recommend heat gun ever on graphic removal.For the guys who installed wraps... what is the best practice for removing the factory graphics off the sled?
they all come off the plastics very easy.
Jafo1970
Everything peels off without heat really easy unlike the doo decals.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Big difference between removing graphics from painted panels vs plastics that are molded in color. They definitely don't stick as well to these plastics.Everything peels off without heat really easy unlike the doo decals.
Now go remove the warning off tunnel.....painted makes for some serious work.
Jafo1970
My 850 doo plastic is just colored molded plastic like the winder but that red stripe on the doo was a bear. Doo must use stronger adhesive. The graphics on the sidewinder painted tunnel actually came off easier than the plastic. The warning stickers suck cause there such a thin material.Big difference between removing graphics from painted panels vs plastics that are molded in color. They definitely don't stick as well to these plastics.
WINDER1987
How's everyone templates doing mine doesn't seem to be a perfect fit on a lot of them compared to my buddies wrap he did on his 6 year old cat from the same wrap manufacturer
Jafo1970
My hood pieces fit together nice but the side panel pieces had some pretty good gaps, most were almost 1/8". Thankfully a sharpie blue marker matches pretty damn close to the blue I used, plus black then.How's everyone templates doing mine doesn't seem to be a perfect fit on a lot of them compared to my buddies wrap he did on his 6 year old cat from the same wrap manufacturer
