Simmons Mounts
Jeffz
Cresco, Iowa
2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
I did some searching on here but couldn't find the thread I was looking for. I remember reading that there were 2 different Yamaha mounts for Simmons skis. There is a set I found that has Yam-N stamped in them. Would these be the correct mounts or is there different mount I need? Thanks!
Super Sled
Riding on the North Shore, MN
Summit X
I have several sets of Simmons skis. 1 set has Ysmaha "V" mounts and the other has Yamaha "V2 " mounts. They are identical except the v2 style has 2 holes, fit mounting the Shia mire forward of the spindle, if desired. These mounts fit Apexes, Nytros, and trailing arm Yamahas I know for sure. I've also heard Simmons makes a mountain sled mount got Yamahas. Not sure what difference would be with that tho. Maybe that's what you have?
