drunkenrich
hey guys
Trying to replace my ski bolt bushings on the 09 xtx and can't even budge them out of the spindle. any ideas? i sprayed the hell out of them
#1Wolverine
hammer small socket and extention bang it back and forth easy does it so you dont mushroom it.
mike3577
- Oct 18, 2009
- auburn hills,mi
- 09 nytro xtx, 8 inch slydog powederhounds, mbrp silencer, ulmer racing clutching, fast track studs,cr10ek sparkplugs,
they do make a bushing driver tool,or do what aws37 said
natedogg3
Just replaced mine. The bushings have a split in them. Find the split and drive a small screw driver under one side of the the bushing. It will separate and overlap the other side. them simply pull out. Worked like a charm when i recently installed my new Ulmer bushings.
good luck!
good luck!
#1Wolverine
Sweet did not know they had a split, I will remember this when i do mine next year.natedogg3 said:Just replaced mine. The bushings have a split in them. Find the split and drive a small screw driver under one side of the the bushing. It will separate and overlap the other side. them simply pull out. Worked like a charm when i recently installed my new Ulmer bushings.
good luck!
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
x2 worked good for me toonatedogg3 said:Just replaced mine. The bushings have a split in them. Find the split and drive a small screw driver under one side of the the bushing. It will separate and overlap the other side. them simply pull out. Worked like a charm when i recently installed my new Ulmer bushings.
good luck!
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
If they are really in there, like mine were. Use a small hacksaw and saw almost through the bushing being careful not to saw all the way through. Then use a small punch and it should just fall out. One cut is all you need, it should calapse the bushing enough to let it just fall out after one whack.
They are a pain though......
