Vmax
- Mar 20, 2018
- Lasalle
- 2014 Arctic Cat ZR 6000 El Tigre
Do Woody's ski savers help with darting?
whitedust1
Navigators?
Vmax
- Mar 20, 2018
- Lasalle
Sorry, what are navigators
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
He’s asking if by “ski savers” you were referring to the Woodys product called “Navigators”
whitedust1
Right ski savers are a wide brush stroke Woodys makes the Navigators as a type of ski saver. Is that the specific Woodys product you asked about?
Also it would help to know what brand ski you are using and what model snowmobile? Lots of very good ski darting solutions available but need to know what you’re trying to cure on what sled and ski.
Vmax
- Mar 20, 2018
- Lasalle
I have Cat skis. Woody's have a flat plate that mounts in front of your carbides. They claim it flattens the snow down so your carbides are on smooth snow. Supposed to help with darting as well as protect your skis.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
If your running a single carbide, I could see using this "flat plate "maybe.. But why not just run Slim jims or the double down snipers? I feel the dual carbides work well with cat skis.. You may want to shim them also..
whitedust1
That sounds like the navigator. Idk how that would work on cat skis but makes sense to come here to ask. I just put woody navigators on doo TS adjustable carbide skis for a 900t with ice ripper track mostly for ski protection and hopefully eliminate a sight dart. Many part number navigators so make sure you select the one that is compatible with your skis so it mounts and works correctly. No one part fits all.I have Cat skis. Woody's have a flat plate that mounts in front of your carbides. They claim it flattens the snow down so your carbides are on smooth snow. Supposed to help with darting as well as protect your skis.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
When ever carbides and ‘darting’ are mentioned I always used to get frustrated when several people would start praising Snow Trackers for great tracking, turning and NO hunting or darting.........then I began to use them for my single keel sled ski’s and NOW its ME.
They flat out work...... better than my Good experience with Bergstrom triples and shim with ski savers. Now I have NO experience with the ‘tuner Snow Trackers’ others can comment on that.
Vmax
- Mar 20, 2018
- Lasalle
I put 4" Woody's dooly's on last season and they did help. I think I will get the skis shimmed and try the ski savers this coming season.If your running a single carbide, I could see using this "flat plate "maybe.. But why not just run Slim jims or the double down snipers? I feel the dual carbides work well with cat skis.. You may want to shim them also..
Thanks folks
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
DO NOT run aggressive sno trackers on CAT SKIS! You will be sorry and maybe even fill your shorts at times.. The Semi aggressive are decent on cat skis.
Vmax
- Mar 20, 2018
- Lasalle
Good to know.....thanks
Vmax
- Mar 20, 2018
- Lasalle
I have read mixed results about snow trackers on the Cat forum. Most like them, they claim it is like have power steering if you use the semi aggressive snow trackers.
They are expensive so not sure if I will try them if the ski toe out and shims do not work next season.
Wannaviper
- Mar 18, 2014
- West Gardiner, Maine
I haven't used the "Navigators" or "ski-savers" you referred to, but years ago we had what sounds similar on our Polaris sleds. It was a wider metal "arrowhead" shape with a narrow metal strip that ran back along the ski between the ski and the carbides. They worked very well, and reduced darting significantly. I suspect that they would help with any darting issues you have.
I will echo Yamadoo though, Snow Trackers work. Until and unless someone invents the perfect ski that prevents pushing and darting, I will have Snow Trackers on all my sleds, regardless of what skis I have on them. The semi aggressive's on Cat skis work extremely well, and the Snow Trackers for Tuner skis are almost as good.
