Vmax
- Mar 20, 2018
- Lasalle
- 2014 Arctic Cat ZR 6000 El Tigre
Any one have any luck with ski toe out and shims to help stop darting?
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
Yep. 1/16" - 1/8" max toe out. Shims to give ski more heel pressure.
Any carbide will perform better set up this way.
Most critical element to proper tracking is ski alignment. Period.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
Yes, absolutely!
Hoosiersnow
How do you measure this - where on the skis? Close to as far to the front and back as you can?
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
- YOUTUBE
- FrozenTows1
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Frozentows4 where do you get the nut bolt combination to extend the carbide threaded studs straight up above ski plastic.
Love the whole drilled in the measuring stick as it allows allot easier on person v. Hooking the stud with the tape measure .
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
Frozentows4, I've had good luck just measuring to the carbide nuts but your system is really fail safe. Thanks for sharing. I will be using this system in the future to adjust toe out.
Vmax, shimming the back side of rubber mount and correct toe out like frozentows4 said are critical to reduce darting. Yamahas new ski for 2021 has a shim set included with the ski. Allows one to adjust to there liking. We've been shimming our skis since 2002 when we bought our first set of bergstrom triple point carbides, its been a difference maker with darting.
Vmax
- Mar 20, 2018
- Lasalle
Snoden
Thanks for the info. I believe my sled needs to be toed out and shimmed. It darts bad and has heavy steering due to I assume too much weight on the front of the ski
Thanks everyone for the great advice. Keep it coming, its going to be a much longer summer due to the state we are all in.
DennyTuna
- Jan 28, 2017
- Ohio
You really shouldn't have heavy steering, what shocks do you have? That's adding to your darting problem as well.
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
- YOUTUBE
- FrozenTows1
It's just a simple bolt coupler found at a hardware store. Then another bolt, with the head cut off, and a lock nut.
The long aluminum straight edge is important to ensure skis are parallel to the track.
Adjust this first.
Then set Toe Out to 1/16" - 1/8" max.
Never Toe In. That will make for heavy steering and poor handling.
- Jun 28, 2004
- Clinton, Wi.
Yamadoo, looks like he's using rod couplers and allthread . Readily available at most good hardware stores. Take a nut off of your carbide for size comparison. 4 rod couplers and
A 1' piece of allthread cut in to 4 3" pieces with 4 nuts to lock the extensions and you'd be good to go.
- Jun 28, 2004
- Clinton, Wi.
Hah, I was to slow lol!
Vmax
- Mar 20, 2018
- Lasalle
I have the Fox Float 3 air shocks. After reading all of the replies it sure seems like I have toe out and ski skim issues. As mentioned my darts badly
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Center shock preload can have a huge impact on steering effort. You may want to try adding some preload to the center shock. Try one to two turns at a time max. If you go too far, you will have very easy steering at the expense of push in the corners..... and has heavy steering....
DennyTuna
- Jan 28, 2017
- Ohio
Exactly! That's where I was headed with shock question first. The center shock acts as your balance point (like a teeter totter), not enough load equals heavy steering and to much load....well fear will set in as your headed for the bush (great hole shot though).
