macpat
I would like purchase of set of ski wheels.
Has anyone ever used or have comments about either of these to brands?
- Retrax
- Skiwheelz
- Rollerski
- Retrax
- Skiwheelz
- Rollerski
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Have tried all three, Rollerski wheels were the best overall in my opinion.
SugarCampApex
- Apr 23, 2009
- Wausau, WI
- 2023 Sidewinder LTX LE, 2006 Apex GT
I have the SkiWheelz and love them. Built really well and easy to install. To retract the wheels, just rock the sled to take the weight off them and they spring up.
Crazy Canuk
I use these: http://www.rouski.ca/avantages_en.html. They work great as well. To retract them, you could rock the sled like mentioned above or just get over a snowbank with a little bit of speed and they spring right up. They were also dead simple to install.
macpat
geeze... seems like they are all about the same price...
thrasher
- Nov 22, 2006
- 06 Vector RS ER
The Retrax wheels jam as snow freezes in them and they sit low on the inside of the skis so they sometimes drag in the snow or kick snow up. The SkiWheelz or Rouski wheels work well but they basiclly hang of the studs on your carbides such they can break the studs or twist your skis. The RollerSki wheels are supported by a custom metal bolt that replaces the ski bolt such that all the weight is on the ski leg, and the return spring is in a watertight housing with oil inside. A little more difficult to install than the others and slightly more difficult to deploy than the Rouski's, but a very good and rugged design.
macpat
Does anyone know which of these (if any) would work on a phazer mountain lite?
Coyote
- Jul 15, 2003
- Laval, Québec
- www.passion-yamaha.com
- Apex XTX 12
thrasher said:Have tried all three, Rollerski wheels were the best overall in my opinion.
x 2
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
I have a set of Retrax if you're interested. They work well, i just hardly used them. In deep powder they would kick snow up. I think they were about $200 new. E-mail if you're interested for dirt cheap...
**sj**
bringing this post back around ....whos using what and likes and dislikes etc
lockburner2000
Interested also??
DJ Hennessy
- Jan 30, 2016
- Barrie, ON
- 2016 Yamaha Viper RTX SE
2006 Yamaha Apex RTX
i have the Rouski wheels. Amazing when going on the road for any distance and having to make a turn on a dime! Only issue I've experienced is when I ran over some ruts from water passing through trail and a good jolt put them into the down position while on the trail... Nothing happened though, prerty durable, just stopped and popped it back to up position and carried on.
provfisherman
- Nov 1, 2015
- Manitoba
- 2016 Vector XTX
2015 Venture MP
Well I have the Rollerski brand. One set on a Phazer RTX and another set on a Venture MP. They work equally well on both machines. On the MP they just mount on with minimal work. On the Phazer, there is some modification that has to be done on the skis. They have to be notched out a little to add some additional angle to the wheels in order for the wheels to stay engaged in reverse. The extra weight of the MP keeps this from happening in reverse so no ski notching required. If you have no intention of using the wheels in reverse, then just mount and go.
Robinmaine
I put on retrax Friday night and rode Saturday. Boy have i been ruining skegs. Ill never go without wheels again. Price is well worth it
Sent from my SM-T817R4 using Tapatalk
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
I put on the Rouski's in the fall and used them this past weekend. Worked awesome getting in and out of the gas station and along the edge of a paved road where in both cases there was no snow at all. The other guys had the tough time of lifting their sleds around because they couldn't steer on the pavement. Very well made for the ski that you are using. They have a sealed spring area and a new bolt replaces the existing ski bolt. I like having the hand lever to engage the wheels rather than the "foot" engage on the Rollerski. Here's the pictures up and down:
