audun34
- Aug 24, 2012
- Norway
- Nytro XTX
KMOD 153" skid
Skinz front end
So without any further investigation I ordered billet timbersled spindles for my Nytro thinking they were pretty similar to stock....But they`re not..
Has anyone fitted timbersled spindles to a non-timbersled front end ?
Im running the Skinz 39" a-arms, and the upper arm won`t fit.
Input appreciated! (with photos)
Mountaintech
Got any pics you can post showing the exact problem?
audun34
- Aug 24, 2012
- Norway
- Nytro XTX
KMOD 153" skid
Skinz front end
Found out that the problem is most likely the upper heim joint. When changing the spindle I also wanted to change out the heim joints for a more beefy version I got
awhile ago from Skinz. They seem to have alot less movement, and then limiting the amount of a-arm movement before the bolt pinches in the joint.
So when I fit it all together the a-arms won`t drop down as much as the used to allowing the upper damper hole to line up with the mountbracket.
Tried to make a spacer under the heim joint to get as much movement as I can.
Any ideas?
Any ideas?
Mountaintech
You need to use a high misalignment heim joint.
- 31K
