shockwave
- Feb 25, 2010
- St Paul d'abbotsford Québec
- 09 Phazer RTX
Looks like I have a new issue to get fix. I am getting a gear skipping noise when I am of the throttle to use the engine to brake. Is sound like some gear are sleeping. The sound seems to come from under the track, or maybe the chains case.
You guys have any idea what is could be?
I hope that my English makes some sense.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Yes, understood. If it was under power or accelerating, I would have said the reverse gear is skipping the dog gears. What about in reverse? I know it would be difficult to decelerate in reverse.
Could also be the drive shaft bearing at the speedometer sensor. It it's that, fix it now before it destroys the sensor.
shockwave
- Feb 25, 2010
- 09 Phazer RTX
I also afraid that it could be the drive shaft bearing. Thanks for the warning, I will store the sled for the season. It will wait for next year when I will get a new track install.
Thanks a lot.
Jean
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Pas de problème mon ami
Look at belt also. That has fooled me already.
shockwave
- Feb 25, 2010
- 09 Phazer RTX
Noted. Will do this summer.
shockwave
- Feb 25, 2010
- 09 Phazer RTX
Well, I found a part of the problem this afternoon. One of the new slide is gone and the rail is well used.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Ouch!
shockwave
- Feb 25, 2010
- 09 Phazer RTX
I paid a shop last fall the get new slides installed correctly to avoid this.
With this situation that just happen, I wonder if this would be a good time to make it a 128. I don't think that I would have to stretch tu tunnel at 128.
This was sure part of my drag problem that I reported before.
- 13K
