ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
While ripping down the lake my sled started missing a little bit. I hammered on the throttle to try to clear it up. Then the sled died completely,. Totally shut down. I tried restarting and it just turned over. Then the battery complet Ely died and I didn't turn it over very much. I ended up walking a few kilometers to my truck and left it there. I will grab another sled and tow it out tomorrow.
Does anyone have an idea what it could be? Sled has Hindle exhaust, power Commander with hurricane map.
Anyway, very strange.
Odds are a coil or crankshaft position sensor. If it starts and runs tomorrow most likely a coil.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
-30 this morning. I will bring my booster pack and see what happens.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
Battery was dead. I guess the fuel injection shuts down at a certain voltage .
Up and running (instead of walking) again!
make sure you load test that battery and make sure the sled is charging before your next adventure. i hate walking when i am sledding too.
Mountaintech
Yup, check to make sure the charging system is operational.
