Winter
- Jan 17, 2021
- Pa
- Rs 90 vector gr
Hi everyone I Recently purchased a 2010 rs vector gt . The sled was serviced by Yamaha every year. Rode it twice then the starter went bad. That was a job!!! Put everything back together and now the sled won’t move. Ugh!!! So far I tried removing drive belt and turned secondary clutch and the track turns freely. Checked alignment between the primary and secondary. Checked the free play on the secondary. The primary is pulling in from what I can tell at the correct rpm. Checked the belt wasn’t sitting to high or to low in secondary. The motor revs to the point that it starts to smoke the belt so it does not seem to be a power problem. If I put it on a stand and the track turns until it is sitting on the ground then it stops moving. Not sure what I am missing. Any advice or tips would be greatly appreciated. Thanks all
Something in the skid jamming the track when set on the floor?
new spring in the primary and a new belt as the one on it might be glazed. springs get weak over time.
Winter
- Jan 17, 2021
- Pa
- Rs 90 vector gr
Tried the new belt. No luck... Did not see anything binding track up. I did notice tonight that it will go in reverse but very slow and it will go forward very slowly if u are standing beside the sled but as soon as there is any weight it stops. Don’t have a spring to rebuild primary. Clutch rebuild might be in line next. I am just not sure why it was fine before I changed the starter but now it’s not. I feel like I missed something or I didn’t put something back together right. lol
ateick
- Mar 11, 2019
- '24 Rene XRS 900R
'18 SR Viper RTX (SOLD)
'20 Poo XCR 850 (SOLD)
Did you set the parking brake?
baggs66
- Nov 18, 2007
- chautuaqua co. n.y.
- 06 apex gt
Is primary spinning on stub shaft, clutch bolt tight?
Winter
- Jan 17, 2021
- Pa
- Rs 90 vector gr
Sorry been stuck at work. No the parking brake was not on and the clutch bolt is tight.
dylanjen9
Sounds like something in chaincase.
Winter
- Jan 17, 2021
- Pa
- Rs 90 vector gr
normal for it to drop after warmed up. how i could tell my rx was rdy to ride lol.
- 9K
