Sinker75
- Jan 8, 2021
- 2007 VK pro, 2000 venture 500XL
Ran some hardpack yesterday, sled got hot, track melted the sliders, and stuck to them. I thought I had them free, but when I went to go, one slider ripped right off the machine. Stupid, and I know better!
So, do I have to pull the skid to change that one slider, or can I do it from a lift? It also ripped the screw out that holds the slider on the rail, so I will have to either tap that out, or make a new one.
Also interested in any tips or tricks you may know to make this easier. I plan to do it tomorrow.
Is this a common problem?
Thanks!!!
S.
Thanks!!!
S.
I always do it in the sled, unless I'm taking the suspension out for other work.
Just tip the sled up partially on its side. Use a good support under the handlebar end to hold it.
Run a tap through that hole.
Take a file or a die grinder to rough the sharp edges at the back of the rail where the slider slides on. Use some soap or something slippery to aid in sliding it on.
Put a little loctite on the bolt.
Norse
- Jan 1, 2019
- Sápmi
- Norway
- 2013 Arctic Cat M1100 HCR 162"
Boondocker turbo 250HP(sold)
2016 Yamaha SR Viper MTX LE 162"
MCXpress 270HP, lots of mods (sold)
2021 Arctic Cat M8000 Hardcore Alpha 155"
N/A (sold)
2023 Yamaha SW MTX LE 153"
M&M Racing 270HP, Elevate, lots of mods
You should be able to install new sliders through drive tooth holes from the rear, just get the track off ground. You can also access that broken screw from the drive tooth holes.
If you're struggling, you can loosen the bolts adjusting the rear wheels, this will loosen the track.
It is a common problem on every sled. You just gotta find some fresh snow to cool the slides every now and then. Make sure to use ice scratchers on hard pack, it really helps.
Sinker75
- Jan 8, 2021
Thanks, and yes, If I wasn't so stubborn I would have taken my fan cooled venture with scratchers on it. It was a bit of a test for the VK and it failed LOL ......What scratchers does every one use? I have the cable style on my venture and they work great for that sled, but its fan cooled, so I don't need much snow. I really thought the VK would have been ok, but i guess that wide track floats so much that it is hard to get down in the snow. My friends on normal track sleds were fine. No damage, just my pride LOL
S.
Norse
- Jan 1, 2019
- Sápmi
- Norway
N/A (sold)
I recommend BRP or cable style, since they're reversible. But any scratcher is better than nothing!
only time i do the slides with the skid out is when i am changing a track. usually use penetrating oil to get them on easyer. if the hole is too messed up on the tip of the rail, i tend to drill through and use a 1/4" counter sunk screw with a lock nut on the top of the rail.
Sinker75
- Jan 8, 2021
Well, I pulled the whole skid out, and still couldn't get that screw out. Tried everything from welding a bolt to it, to drilling it. Nothing worked. I ended up drilling and tapping a new hole. Got the skid all looked over and greased up again anyways, and installed scratchers so this doesn't happen again. Took it for a rip yesterday on basically glare ice and it was no problem with the scratchers. I'm a fan cooled guy, not used to these liquid cooled 4 strokes yet, but I will figure them out.
S.
S.
