jrice1987
Rebuilt and cleaned carbs on rx1 slight gas mist in mouth of all 4 carbs is this normal.
jrice1987
It's mistingup thru the needle. Runs a tad rich at idle
jrice1987
Im not sure why they would it would be misting that all the o rings were replaced
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
Did you clean them on or off the machine?what did you replace?did you remove 1 bowl&clean 1 at a time?Is this your first time cleaning them&Do you run ethanol fuel?was this just preventative maint or were you having running issues?Did you have the fuel tank off&change the filters? sorry for the barrage of questions but these carbs have a lot of parts&even guys that are experienced with them have trouble sometimes,ty member stomper had his apart so many times last year he could do it with his eyes closed!!once we know more about how the machine was running&how the cleaning went we can probably help figure it out.Im not sure why they would it would be misting that all the o rings were replaced
jrice1987
Yes I took them off, sled sat for 2 years,replaced lines, they were not to cruddy actually, but o rings were toast, also replaced needle and seat, cleaned everything pretty good, I thought the floats were set at lean side so I dropped down some. Did not sync carbs but i will, it idles fine and runs good, a little rich at 1/4 throttle, but as soon as I open it up it goes away. I think I set the floats down to far causing it to fill up to much and come up through the jet needle. I will try setting it back where it was.
Brotherdan
- Sep 8, 2017
- Belmont,maine
Float height should be 11-15mm,measured from where the bowl mounts to the flat section on the floatYes I took them off, sled sat for 2 years,replaced lines, they were not to cruddy actually, but o rings were toast, also replaced needle and seat, cleaned everything pretty good, I thought the floats were set at lean side so I dropped down some. Did not sync carbs but i will, it idles fine and runs good, a little rich at 1/4 throttle, but as soon as I open it up it goes away. I think I set the floats down to far causing it to fill up to much and come up through the jet needle. I will try setting it back where it was.
the rx sleds always spit back a touch especially in warm weather. my 05 always had a residue in the air box when i opened it. brother owns it now and it still does it with 17000 km on it.
jrice1987
Ok I guess I'm a dummy lol, but I'm confused on where to measure the float height from the flats on the float or the highest point on the ?
Brotherdan
- Sep 8, 2017
- Belmont,maine
See my reply above,measure to flat section on floatOk I guess I'm a dummy lol, but I'm confused on where to measure the float height from the flats on the float or the highest point on the ?
jrice1987
Are you 100% sure?, I was leaning towards the highest point on the float
Brotherdan
- Sep 8, 2017
- Belmont,maine
Brotherdan
- Sep 8, 2017
- Belmont,maine
In the search box on this site type in float level&see the first post where supertuner (Freddie rip)gives the way he did it&he was a masterAre you 100% sure?, I was leaning towards the highest point on the float
