SledFreak
- Feb 7, 2005
- Ontario. Canada
Any performance gain from it?
welterracer
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
I know the front idlers are designed to pull the snow in, and the rear wheels take the snow out. ( When set up correctly ) I would say the performance gain here would be cooler slides and perhaps less build up of snow packed skid.
storman
Are these wheels larger diameter than stcok as to help out with hyfax and rolling resistance? Been reading about all the wheel options and want to try somthing but still havnt pulled the trigger.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Are the rear wheels any bigger, then stock?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
The front idlers are larger than stock, yes. They are 5.35" in diameter. The rear idlers are stock diameter.
sheetwright
SISCAKIDD
allen,can i get these in just black and white.
sheetwright
SISCAKIDD said:allen,can i get these in just black and white.
Just so you know the lighting makes the white on the Slydog.Ulmer bogies glow. Cool thing most guys don't know. IMO
- Apr 17, 2003
- Menno, SD
- Menno, SD
Yes we can do black & white. I just did a set for a customer that we'll be installing here.
welterracer
YamaMTX
I was wondering your thoughts on the wheels being larger as there are several posts on her about larger bogies causing stress cracks to the rails? maybe a myth. I would like to add larger wheels to slow hyfax wear down but don't want to cause other issues. I ride a 2009 Nytro MTX
welterracer
I have 9000 miles on my sled.. No cracks in the rails that i have found...
They definitly help the slides last longer..
- 46K
