Slydogs & ski alignment
raptordan
Barrie ont.
Canada
2025 SRX
I just purchased a set of slydog race skis and 6 inch shaper bars.I read somewhere here that these skis need to be toe in ? Is this correct and if so why when all other skis are to be set with toe out.Thanks for the help :yam:
You will have to check for toe in. You don't want this, you will want to have I believe 1/4 inch toe out. Some one correct me if I'm wrong, it's been a while since I did it.
I have mine an overall 3/8" on my C&A Razors for cornering
On Slydog skis you want them set at 0 or 1/8" toed in. The skis will flex out when driving that is why you want the toe in on the Slydog skis.
Thanks for the help Srxspec I knew I read some where here they needed to be towed in a bit.The other question I forgot to ask was which way should the ski rubber go?Right now I have the tall end to the back.Is this right.
On the FX Nytro & Phazer models the tall end of the ski rubber goes towards the rear of the ski. You have it installed correctly.
I rode all year last year with slydogs and tried the toe'd in theory............ it was horrible to the point where it almost bucked me off once slowing down on a road. I have since milled my upper balljoints and gone to a 1/2" toe out and the handling is 100x better....... I guess to each there own!
