Quinton Keats
- Mar 12, 2018
- Churchill Falls
- 2016 Yamaha Pro 2
As anyone got the strong smell of gas under load, I have a 2016 vk pro 2 with 800 kms and I have notice a couple of time now that I get a strong small of gas when I put the engine under heave load. I have looked for a gas leak but never found anything and was wondering if this was a normal thing or if I have a problem.
arthur taylor
- Oct 9, 2015
- Fort Smith, NT
- 2007 RS Rage GT
I logged in to make this comment as well. notice a strong smell of gas while riding. Occurs more at slower speeds, and while dragging a loaded boggan. I've stopped to inspect fuel lines, gaskets, etc because it smelled like i was inhaling gas directly from the tank.
Quinton Keats
- Mar 12, 2018
- Churchill Falls
- 2016 Yamaha Pro 2
same conditions, I was pilling a bogan that was about 500 lbs at slow speeds in low gear,
North Bay Ned 691
Yes I too smell gas on my machine. Normally it is when I am on rough or bumpy trails going slow. On one occasion I had gas pour out down into the bottom of the clutch area upon fill up. I would suspect the gas came out the overflow but cannot understand why the overflow would allow gas to leak into the engine compartment. I suspect i have a hole in the fuel tank. My machine is a 2016 VK Professional as well.
chateaupitsie
- Nov 10, 2017
- Nunavut
- 2011 550f grand touring, 2000 440 Bearcat, 1998 340 Bearcat, 1984 Scandic 503, 1989 Safari 377, 1988 Bravo LT,1983 Everest 500, 2009 600 Polaris Switchback, 2016 VK Pro ii,
Good day! I have a VK Pro ii 2016 as well. I also get the gas smell. Got it today pretty strong opened hood, couldn't see any leaking. Maybe someone should see if the Yammaie experts can review for us on line. Gas smell is scary, don't want a fire while underway!! That happened with my 2009 switch back a few years ago, not Fun!!
BACK COUNTRY YAMAHA
- Nov 26, 2015
- newfoundland
- 1997 vmax 600 sx, 99 venture 600, 2004 vk 540, 2006 Yamaha vk pro, 2009 venture multi purpose and 2006 venture 500 xl current ride 15 rs viking pro
What happens is that when you work the sled hard, the exhaust runs under the fuel tank and when the fuel starts to get warm it expands and creates more vapour and it vents out down in the frame above your left foot aft of your clutches, this is where you get the smell of gas from! Had this on my 06 pro nothing to worry about! And for he carb versions where you operate your sled in warm conditions and working the sled hard you have to turn off your coolant flow to your carbs this will also vapour lock the carbs causing the sled to cut out and create a smell of fuel! Cheers!
chateaupitsie
- Nov 10, 2017
- Nunavut
Very Good Back Country !! Thank you, that seems to explain the gas smell!!
North Bay Ned 691
I am with you but I actually had fuel leaking inside the engine compartment on the left side below the clutches. I am thinking the vent line maybe came off or maybe a hole in the vent line. I looked for something obvious but could not see anything specifically. Dealer is going to take a look at it in the next week or so. Thanks for the info.What happens is that when you work the sled hard, the exhaust runs under the fuel tank and when the fuel starts to get warm it expands and creates more vapour and it vents out down in the frame above your left foot aft of your clutches, this is where you get the smell of gas from! Had this on my 06 pro nothing to worry about! And for he carb versions where you operate your sled in warm conditions and working the sled hard you have to turn off your coolant flow to your carbs this will also vapour lock the carbs causing the sled to cut out and create a smell of fuel! Cheers!
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Now that makes sense. I remember trying to pressurize the tank to siphon and smelling it just like he describe............good info.
YukonMP
- Dec 25, 2014
- Yukon Territory
And we know Back Country is an authentic Newfoundlander because he says aft instead of behind. Nice.
Quinton Keats
- Mar 12, 2018
- Churchill Falls
- 2016 Yamaha Pro 2
keep us informed of what the dealer has to say about this. I'm 250KM from the nears dealer, and is unable to take my machine to the dealer this year. It was about -30C ambient temperature out the first time I got the smell of gas under load condition, and I also got the smell at -10c under load conditions.
BACK COUNTRY YAMAHA
- Nov 26, 2015
- newfoundland
if you over fill your sled, it will puke gas out the vent, if you consult your owners manual it tells you the level to fill it , we are all guilty of trying to jam as much fuel in there as possible even burping in between. Also I have heard of owners removing the white sleeve that is there to prevent the over filling ! Cheers!
Tunepipe
- Oct 5, 2014
- Sormany
- VkPro, Venture TF, Phazer, Snoscoot 200...Sidewinder, Excell III
Exactly what BACK COUNTRY YAMAHA said is the issue, if you don't have a gas smell you're not working it hard enough...What happens is that when you work the sled hard, the exhaust runs under the fuel tank and when the fuel starts to get warm it expands and creates more vapour and it vents out down in the frame above your left foot aft of your clutches, this is where you get the smell of gas from! Had this on my 06 pro nothing to worry about! And for he carb versions where you operate your sled in warm conditions and working the sled hard you have to turn off your coolant flow to your carbs this will also vapour lock the carbs causing the sled to cut out and create a smell of fuel! Cheers!
chateaupitsie
- Nov 10, 2017
- Nunavut
Good day!! -26 not pulling a heavy load, not being overworked, gas tank at a half tank, not overflowing!! Gas smell still evident but not any gas showing up just fumes. As well the windshield on the VKPro 2016 ices up. It seems that heat from engine comes up onto glass...., after -25 ambient temps it is a problem. Didn't happen last spring when we were running -20 and warmer outside.
