RCk
- Dec 12, 2014
- Tughill, NY
- 2020 Sidewinder LTX-LE 2015 Apex XTX , 2013 RS Venture GT,09 RS Venture GT .05 RX Warrior
- Tughill, NY
Use Map gas with torch it burns a little hotter. I would give it a shot with vise grip. Just get the vice grip as tight as possible.
TurboAddict
- Jan 8, 2018
- Georgetown ON
- Sidewinder X-TX SE
Welder didn't work, but a couple broken drill bits later... It's out!
Ended up getting a left hand (reverse) drill bit. 1/4" and picked it out, just ran a tap throught to clean up the threads. Also picked up the SS bolts, lock washers and nickel anti seize!
TurboAddict
- Jan 8, 2018
- Georgetown ON
Recommendation on torque spec?
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Turboflash
- Mar 18, 2019
- Southern MN
Factory torque spec is 18 ft.lbs.Recommendation on torque spec?
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I have used that trick many times before..........Ended up getting a left hand (reverse) drill bit. 1/4" and picked it out
Pstn head
9ft lbs then 18 criss crossRecommendation on torque spec?
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
SS is softer, with the lock washers, I think the most I've torqued to is 15 ft lbs with zero leakage.Recommendation on torque spec?
Turboflash
- Mar 18, 2019
- Southern MN
As many of us know, with a bolt that size and a T50 Torx, it would be very easy to tighten way past 18 ftlbs. Over-tightening you can actually warp the turbo flange where the muffler bolts up to.
Why cant you guys use studs here? Just no room? That would be the right way to do this long term.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
It would make it a pain to get the muffler on and off. The way is slides into the mounts would make it hard to get it over studs.Why cant you guys use studs here? Just no room? That would be the right way to do this long term.
Turboflash
- Mar 18, 2019
- Southern MN
For sure. At the bottom of the muffler mount, there is a peg that's about an inch long, maybe longer that has to into an isolator. Studs would make it really hard to get that in place.
TurboAddict
- Jan 8, 2018
- Georgetown ON
Well successfully got it back together, was glad to get that PITA fixed. Brought the exhaust bolts to 15ft/lbs. I will keep a close eye. The factory torque spec on the chaincase cover I feel is also to high at 12ft lbs. Twisted one bolt right off, luckily it came out easily. Went by feel with the new bolt, no leaks.
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
Copper Anti-seize ??
TurboAddict
- Jan 8, 2018
- Georgetown ON
Yes! Anti-seized every bolt, and probably every finger...
