blown apex
which snowtrackers should i get
semi agressive or agressive
06 apex gt
06 attak
06 apex gt supercharged
i cruise mostly but ride hard sometimes with studs
two sleds have 121 and the other has 136
im sick of the darting and hard turning
(tried duallys/slimjims/ca razers)
lightened up front springs/increased transfere
im tired of adjusting just want a fix
will shimming slim jims help with darting and hard turning
seems way worse this year(possibly warm temps)
thanks
oh were do i buy snowtrackers
06 apex gt
06 attak
thanks
JROCK
- Oct 25, 2007
- Ottawa, Ontario
- 2006 Yamaha Apex GT
Aggressive all the way! You wont be disappointed.
Boston RX1
I just purchased 3 pairs with no seat time yet and I was told nothing but aggressive.
FrostyNutz
I've been using the Semi aggressive for over 2K km's. No signs of wear and all the darting has been eliminated. I was told that the aggressive trackers make it hard to cross asphalt , leaving you stuck at the pumps , slow you down on ice , and generally just too aggressive on hard packed .
kviper
I have 6K on Tracker's now and will never ride with out them again! Only you know how hard you want to corner. Other than that either will transform your sled. Set toe to 0 with stock rubber and no shim's!
kinger
Where can you buy these in US?
KevinS
I would also consider Dartless plates. Last year I ran Aggressive Snowtrackers. Between those and a track swap I lost 10 mph. This year to try and get some speed back I swapped out the Aggressive Snowtrackers for Dartless. I cannot tell a difference between the two except for cost.
Dartless works just as well as the Aggressive Snowtrackers.
kinger
That is what I am after as well more top speed no darting. Thanks for the reply KevinS.
kviper
I drag race with bus's all the time and noticed no top end loss from the Tracker's. I would bet your top end loss is from the track. What track did you have and go to?KevinS said:I would also consider Dartless plates. Last year I ran Aggressive Snowtrackers. Between those and a track swap I lost 10 mph. This year to try and get some speed back I swapped out the Aggressive Snowtrackers for Dartless. I cannot tell a difference between the two except for cost.
KevinS
kviper said:I drag race with bus's all the time and noticed no top end loss from the Tracker's. I would bet your top end loss is from the track. What track did you have and go to?KevinS said:I would also consider Dartless plates. Last year I ran Aggressive Snowtrackers. Between those and a track swap I lost 10 mph. This year to try and get some speed back I swapped out the Aggressive Snowtrackers for Dartless. I cannot tell a difference between the two except for cost.
Went from the stock Ripsaw to the 1.5" Ripsaw. I am now down to a 1" Hacksaw. I haven't ridden it yet since the 1" was put in.
FrostyNutz
kinger said:Where can you buy these in US?
I'm not sure if these part numbers will work for you in the US . They are available from Yamaha Canada.
SnowTracker Semi-Aggressive Kit
SMA-20413-00-00
MSRP: $215.95
SnowTracker Aggressive Kit
SMA-19413-00-00
MSRP: $239.95
kviper
1.25" to 1.5" with same track will probably cost you 5 mph min.KevinS said:kviper said:I drag race with bud's all the time and noticed no top end loss from the Tracker's. I would bet your top end loss is from the track. What track did you have and go to?KevinS said:I would also consider Dartless plates. Last year I ran Aggressive Snowtrackers. Between those and a track swap I lost 10 mph. This year to try and get some speed back I swapped out the Aggressive Snowtrackers for Dartless. I cannot tell a difference between the two except for cost.
EX TOPGASSER
snowtrackers
I have a set of aggressive with less than 100 miles on them which I'm willing to sell.
