Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
Its important to fix this if it has moved when you blow a belt, becouse if the shaft has moved then the next time you blow a belt then the crank will take the side force of the impact the shives make when they bang together.
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
Yes! It will be heat when the primary is rubbing against those 4 bolts.Is it possible that this couldve been making excessive heat in the clutch?
x600c
- Mar 11, 2013
- maine
- Sidewinder
My clutch looks the exact same. Also been having belt problems recently...
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
I have a 2018. Never had the clutch off. Just outer half. Replaced my 17 with button heads but figured they would've addressed this problem. Is this actually still an issue in 18? If so I'm disgusted and totally disappointed.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
I am going to ask a stupid yet obvious to me question...leaving the four bolts intact...why couldnt one use the clutch retaining bolt with the slide hammer and pull the stub and shaft back out?
Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
I tried, didn't work, maybe need a B'rFSH. Its probably not as easy as we'd think because the press fit is all that holds the shaft in place. The design shouldn't allow lateral movement or they'd all possibly move inward eventually.I am going to ask a stupid yet obvious to me question...leaving the four bolts intact...why couldnt one use the clutch retaining bolt with the slide hammer and pull the stub and shaft back out?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Another question... to Whoever.... When you add your primary bolt and torque... Are you using grease on the bolt or thread locker?
Soupy
- Jan 10, 2017
- West Michigan
Neither. I use oil.
x600c
- Mar 11, 2013
- maine
- Sidewinder
So has anyone been able to fix this? Or do you guys just put button head bolts in and run it?
Soupy
- Jan 10, 2017
- West Michigan
Mines at the dealer getting parts replaced and fixed. I highly recommend fixing it. Heat, offset, etc problems.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Imho add nothing... Any liquid throws off the torque read and over torques
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
Yamaha tells you to oil the bolt, Tq to 108 Ft. Lb loosen bolt and Tq to 43 Ft. Lb.
x600c
- Mar 11, 2013
- maine
- Sidewinder
Anyone know the torque spec for the 4 stub shaft bearing retaining bolts?
KnappAttack
- Feb 19, 2004
- Welch MN
Service manual shows 8.7 ft. lbs. So 105 inch lbs.
Soupy
- Jan 10, 2017
- West Michigan
Sled is back from the dealer. They replaced stationary primary sheave, primary mounting bolt & stub shaft #*$&@'y (bearing, seals, shaft) under warranty. Pic showing newly installed stub shaft #*$&@'y bearing.
Primary is now 2.5mm further away from the engine so no more hitting the bolts heads and much further from the water pump & it's heat. Pic showing bolt head clearance behind primary.
With no shims I can now get down to 58.7mm offset, which is refreshing considering my belt appeared to be doglegged and in need of less shim.
I'm hoping that the new parts, changing the offset, not rubbing bolt heads and the primary being farther away from the engine will reduce heat and help to stop blowing belts.
- 17K
