Snowmobile Mike
- Oct 19, 2018
- East Haven Connecticut
- 2016 Yamaha XT SE
Thanks for heads up !For all of you going to the dealer for the latest flash and had backfires recently,
CHECK YOUR MUFFLERS... if factory they are likely damaged.
Especially the backside, it cracks almost 100% of the time.
Look up my previous posts.
I have had muffler off for maintenance it WAS fine ! I wouldn't think this one time did anything, sure hope not , noise sounded like some two strokes in the past in beginning of season where not so fresh gas etc ! Man I can't WIN haven't even rode it yet and MAY have to go back to dealer for this NEW Flash !
cobrajet ltx dx
- Oct 5, 2014
- pa
- 2015 yamaha ltx dx
It’s not all bad!!!!Thanks for heads up !
I have had muffler off for maintenance it WAS fine ! I wouldn't think this one time did anything, sure hope not , noise sounded like some two strokes in the past in beginning of season where not so fresh gas etc ! Man I can't WIN haven't even rode it yet and MAY have to go back to dealer for this NEW Flash !![]()
Had 8000 miles of pure smiles,and fun having skidoo’s chase me all around Quebec.
The motor is freaking addicting.
But also had to deal with the WTF is this #*$&@ for 8000 miles.
Seen every bad characteristic of the viper unfortunately.
Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
Other dealer going to charge half an hour he is double dipping cause yamaha pays him for thisYep had reflash yesterday ,New England Cycle Center in Hartford Ct.Yamaha dealer ! Glad it's done eee ! This dealer no charge other Dealer said they probably would have to charge me a half hours time !
I have only started this sled on trailer and on stand in garage ! It SEEMS To start quicker but that could be illusion !
Yamasledder
- Mar 7, 2010
- Brandon, Manitoba, Canada
- 2020 Viper LTX SE
I had my 2014 Viper RTX reflashed this morning with the latest update. This sled has always run flawlessly from the time I got it 2 years ago once it was warmed up. However; when starting cold after the 2016 flash, it would let out a heart stopping backfire occasionally and would be very hard to start below about -15C. After it started from cold, the engine sounded very labored and idle rpm would continuously vary. (engine hot and cold). Most times when starting at operating temp, it would take 2 attempts to get it running.
I have not had it out on the snow since this mornings reflash but have these observations. It cranked several times at -18C (O f) and started without an issue. It idled well cold and rpm's only varied by 10 between 1490 and 1500. I let it warm up on the trailer until the fan ran and then shut it off. The fan now runs quite a bit longer after the engine is shut off than before the latest flash but that's not an issue at all. I started it and shut it off (engine warm) several times at the dealer with single start on the key every time. I then took it home and the engine was cold again when I got there. I went through the start and warmup process again and it performed flawlessly. I then tried restarting it warm several times (warm) and it started first time every time. This would not have been the case before the reflash. One other thing I noticed is when I increase the throttle to just below clutch engagement rpms and then quickly release it, the engine slowly returns to idle speed whereas before it would drop very quickly to idle speed. (not an issue; just an observation)
Overall, I'm very happy with how this turned out and look forward to getting it out on the snow. Hopefully it still performs well. If this problem has actually been solved, I may go and buy a new one someday as I really like these sleds. If this flash turns out to be a dud, I am going to change teams. 5 years is long enough to wait for a solution.
Northshore
- May 16, 2018
- Sudbury
- 2015 Viper XTX
Thanks for the detailed reply
CharlieAZ
- Dec 20, 2016
- Nutrioso, AZ
- 2015 Yamaha SRViper LTX DX and 2005 Yamaha Vector RS ER makeover 2017/2018
- Vail,az
- AOL
- Palmercmp0466@aol.com
Got mine done today , Drove 5 hours one way to get it done... Long day, just got home about hour ago, and left at 7:30am this morning...
CharlieAZ
- Dec 20, 2016
- Nutrioso, AZ
- Vail,az
- AOL
Put 100 miles on since ECU Flash update .... No issues to report .Got mine done today , Drove 5 hours one way to get it done... Long day, just got home about hour ago, and left at 7:30am this morning...
CharlieAZ
- Dec 20, 2016
- Nutrioso, AZ
- Vail,az
- AOL
Short Video of Ride after Flash Update:
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
So, is anyone noticing any more power? Having to change clutching or getting another few mph out of it?
I would take mine in tomorrow if someone got another 3 mph from it. Mine has always started pretty good, except for flash number 1 in 2014.
yamajammer76
- Apr 6, 2005
- Black Hills, SD
- 2024 Arctic Cat Riot 600 1.75
I had the flash done on my '16 yesterday. I rode 107 miles today and it's great! Starts and idles like my Nytro did. It seems like the entire powerband from start to full throttle has been "cleaned-up" for lack of a better term. Maybe Textron brought some better engineers in because whatever they did it's a big improvement.
Dinner
I’ve read in another posting somewhere that the rpm limit was raised 100rpm. Can anyone confirm this that has had the flash done? If people are noticing better starting, idle and the entire rpm range seems smoother, I will probably take mine to get done.
I believe ulmers post said 50rpm.I’ve read in another posting somewhere that the rpm limit was raised 100rpm. Can anyone confirm this that has had the flash done? If people are noticing better starting, idle and the entire rpm range seems smoother, I will probably take mine to get done.
mbeaunh
- Sep 18, 2016
- N.H.
- 2013 Nytro XTX, 2014 Viper RTX
Bringing mine tonight. Hopefully I get the same result!
So at least 150 rpm increase since original 14flash. Those of you banging rev limiter due to clutching it might be enough to avoid it.
- 11K
