bigal1951
- Oct 17, 2008
- St. Andrews, MB
- 2014 SR Viper XTX
2004 RX Warrior
My 2014 SR Viper XTX will not start in cold weather. Just cranks, sputters once in a while and backfires through the muffler. I bought it from the original owner and has only about 6,000 kms. Any ideas.
Confused
- Oct 12, 2008
- Mound, MN
- '21 Sidewinder LTX SE
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
When's the last time you replaced the spark plugs?
bigal1951
- Oct 17, 2008
- St. Andrews, MB
- 2014 SR Viper XTX
2004 RX Warrior
Never.
Confused
- Oct 12, 2008
- Mound, MN
'24 MXZ Neo+ 600
'88 SnoScoot
I'd start there. I change mine every year.
Yamasledder
- Mar 7, 2010
- Brandon, Manitoba, Canada
- 2020 Viper LTX SE
Has it had the latest computer update? Sounds like it's still on the old program.
Snowfun
- Dec 7, 2014
- Waterdown, Ontario
- 2022 SRViper L-TX GT
Make sure that you fill the tank each night to keep the condensation out of it. I put premium gas line antifreeze in each night too.
turbogts22
- Jan 16, 2021
- Spooner, Wisconsin
- Two 2010 Phazer GT's
Tight exhaust valves possibly?
JASONDEGUIRE
- Jan 22, 2022
- collingwood
- 2010 yamaha vector
start with plugs easy and cheap, if not then check if you are getting spark could be one of the coil packs
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Frozen fuel pump relay, or battery voltage drops when really cold, will crank but not start, try giving it a jump while starting
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
These are really sensitive to battery voltage. If its super cold out, I throw a tender on for an hour before I try and start it. Also, when you are starting it, keep the key turned on even if it fires. They like to fire right away then when you let off the key, it loads it with fuel the next time and makes it hard to start.
bigal1951
- Oct 17, 2008
- St. Andrews, MB
- 2014 SR Viper XTX
2004 RX Warrior
Well; I got the plugs out today to replace them with new ones. Man, we’re they ever BLACK. No wonder the thing wouldn’t start. Going to put all the plastics back tomorrow and give her a try. Hope this solves my problem?
crunchie
- Jan 23, 2023
- Quebec
- 2015 SR Viper R-TX DX
I know this thread is a year old but did changing your plugs help at all. tksWell; I got the plugs out today to replace them with new ones. Man, we’re they ever BLACK. No wonder the thing wouldn’t start. Going to put all the plastics back tomorrow and give her a try. Hope this solves my problem?
MaineSRViper14
New to the group and have a few questions that have been answered partially here and there but wanted to get them all in one post relating to my 2014 SrViper xtx issues. I’ll be totally honest when I say I’m a newbie when it comes to four strokes. I’ve always owned two strokes in the past.
I recently bought my 14’ Viper from an older gentlemen that said he hasn’t ridden the sled much since he bought it. There was half a tank when I bought it so I saw a lot of suggestions on the forum to put seafoam additive hoping this may take care of a potential bad/old gas problem. I had only driven it around my yard and down a trail behind my house and it seemed to run ok. The weather has turned colder and today it didn’t want to start. Pump came on but just kept cranking. Took about 7 or 8 tries before starting. Then after riding a few hundred yards it sounded like it was running on one lung. Very boggy and that bogging down sound. I’d appreciate any advice. Thanks
welcome.
have you called a dealer with the serial # to confirm it has the latest flash in the ecu?
14 did have issues with the vipers starting wonky. throwing a new set of plugs in it will not hurt as old gas will foul them some times.
MaineSRViper14
I haven’t called a dealer yet. The guy I bought it from said he had recalls fixed but I’ll bet you’re right and it has t been updated. Thanks!
