Bert Corrigan
I have a 2019 SRX Sidewinder that has 368 miles on it. Ive changed the oil and filter thanks to Dan. But I need step by step guidance on the procedure to change the chain case oil. Right from the start. I’d appreciate any help I can get
Thank you
Bert
Thank you
Bert
SaskAttack
- Jan 4, 2006
- Corning,SK.
- 17 Sidewinder XTX-SE
- Corning, SK. Canada
Number 53 I believe , https://ty4stroke.com/threads/my-rtx-le-50th-build-thread-rockerdan.149801/, make sure to thank Dan for his work.
Bert Corrigan
Thank youNumber 53 I believe , https://ty4stroke.com/threads/my-rtx-le-50th-build-thread-rockerdan.149801/, make sure to thank Dan for his work.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
When you get it apart take the time to clean the Torx bolts and holes. Run a tap in the holes and die over the bolts
When reinstalling many guys have stripped the threads. When they are all clean with new loctite it is way easier to feel them when reinstalling.
Ms
Ms
Bert Corrigan
I got it figured out. Watched the old video on this. Thank YouI have a 2019 SRX Sidewinder that has 368 miles on it. Ive changed the oil and filter thanks to Dan. But I need step by step guidance on the procedure to change the chain case oil. Right from the start. I’d appreciate any help I can get
Thank you
Bert
Carbide
- Apr 20, 2017
- Elk River, Minnesota
- '15 Apex X-TX -SOLD
'21 Sidewinder L-TX SE
- Minnesota
368 miles? No snow there?
sab2022
How do you read a sidewinder sight glass? Do I need a infrared light? Carry a flashlight? Check when is hot? Cold 1/4" in the glass, hot 1/2" I wonder what my owner manuals says.
All I see is black in the sidewinder sight glass ... maybe its empty...
Carbide - some small ponds have thin coating of ice according to the ice fishing forum I follow their hoping for walk-able ice by xmass
sailor joe
- Apr 4, 2019
- ma
- 2016 RS VENTURE TF
2020 SIDEWINDER GT
lake Unbagog was frozen over last week...it wasn't thick but it was froze.How do you read a sidewinder sight glass? Do I need a infrared light? Carry a flashlight? Check when is hot? Cold 1/4" in the glass, hot 1/2" I wonder what my owner manuals says.
