Hi, I bought an Apex clutch kit stage 2 for my LTX-GT 2010.
I run with the 24th gear. Other friends run with 24-25th gear...
So May I will have to change something with the tips?
What is the killer setup for acceleration 30-100mph...no 0-xxxmph.
You may have to remove a washer from the tips of the weights with the 24 tooth gear, but if you are only after 0-100 mph acceleration then I would leave the 23 tooth gear in.
