Todd Beenen
You better hold on
Pstn head
And tighten up those handlebars!
Kuzzy
- Dec 6, 2020
- saskatchewan
- 2020 yamaha sidewinder xtx se
2022 STX GT
2017 King Cat M9000
Ain't that the truth, even in stock form they aren't tight enough.And tighten up those handlebars!
Turboflash
- Mar 18, 2019
- Southern MN
What gas are you planning on running? I wouldn't trust my local 91 for that tune. IMO, minimum 95 octane, maybe more?
Yes, I know what they advertise but where I live, the gas has gotten worse and worse even though it says 91 or 92 on pump.
Should be a rocket!!
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
93 pump. Of course I'm going to keep an eye on it. Should be able to run 22 lbs on it.What gas are you planning on running? I wouldn't trust my local 91 for that tune. IMO, minimum 95 octane, maybe more?
NYTurbo
The GAP knock protection works very well and will help identify octane issues
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Dmcturbo what gear you going to run ?
DMCTurbo
- Nov 12, 2005
Big onesDmcturbo what gear you going to run ?
Kenzie
- Feb 27, 2015
- Viper ltx se 137 turbo
I might have missed it but is this a more snow drag or radar focused build?
DMCTurbo
- Nov 12, 2005
RadarI might have missed it but is this a more snow drag or radar focused build?
DMCTurbo
- Nov 12, 2005
More progress, valve lash checked, 1 valve out of spec. 13000km on the sled. ARP head studs torqued to 65 ft lbs. The top left set at 82mm or roughly 3 turns out. Once you install it rotate the motor slowly to verify the stud is clearing the water pump gear. All others backed out 1 full turn. Red loctite installed. When torquing they will turn slightly. Not much you can do.
Next was cam timing. It was a little tricky, took me a couple hours to figure it out, 1am when I finished. Will be double and triple checking it tonight before the valve cover goes on. Follow the shop manual for this. All in all not too bad of a job. Take your time and invest in the right tools. This was my first time opening up a 4 stroke.
Thanks to my friends Travis, Brian and Prevost Performance for answering my million questions.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
did you put manual tentioner in? and the heavy dutty chain? thats what Mike at TD did for mine. i put 25/45 gears in mine... larger radius less rolling resitance and more teeth in chain.
DMCTurbo
- Nov 12, 2005
Manual tensioner yes but I didn't upgrade the timing chain.did you put manual tentioner in? and the heavy dutty chain? thats what Mike at TD did for mine. i put 25/45 gears in mine... larger radius less rolling resitance and more teeth in chain.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
at least the manual tenioner will stop you skipping a tooth if engine turns backwards
Turboflash
- Mar 18, 2019
- Southern MN
Who/where did you get the torque specs for ARP studs? When I installed mine 3 years ago, ARP told me 12-25-55. First time I've heard 65.More progress, valve lash checked, 1 valve out of spec. 13000km on the sled. ARP head studs torqued to 65 ft lbs. The top left set at 82mm or roughly 3 turns out. Once you install it rotate the motor slowly to verify the stud is clearing the water pump gear. All others backed out 1 full turn. Red loctite installed. When torquing they will turn slightly. Not much you can do.
