DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Turbo dynamicsWho/where did you get the torque specs for ARP studs? When I installed mine 3 years ago, ARP told me 12-25-55. First time I've heard 65.
Turboflash
- Mar 18, 2019
- Southern MN
I'm guessing the difference is your saying 65 ft.lb. using one of TD's "HD" head gaskets? The 55 I've been using is for a stock Yamaha head gasket.
NYTurbo
65 is what everyone is using now.
Turboflash
- Mar 18, 2019
- Southern MN
10-4. Tks.
DMCTurbo
- Nov 12, 2005
Reassembly day.
Turboflash
- Mar 18, 2019
- Southern MN
Looks like maybe some of the vent slats in in the top of the tunnel are bent shut or close to it? Are you gonna straighten them out? Lots of these tunnels do this from ice chunks. Most of the ones I work on I have to open them back up.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Dude I like what your doing to your hotrod there.Reassembly day.
I have the same sled as you bought first year.
Mines a hotrod also.
Enjoy!
DMCTurbo
- Nov 12, 2005
Thanks 1nc. Don't see the need to replace it as of yet seeing not much has changed since year 1 just keep making it better.Dude I like what your doing to your hotrod there.
Enjoy!
DMCTurbo
- Nov 12, 2005
Ya I usually have to open some of them up every time I have the gas tank off.Looks like maybe some of the vent slats in in the top of the tunnel are bent shut or close to it? Are you gonna straighten them out? Lots of these tunnels do this from ice chunks. Most of the ones I work on I have to open them back up.
DMCTurbo
- Nov 12, 2005
TD header installed. A little trimming of the heat shield required but it went together quite easily. Turbo with upgraded wastegate installed. Exhaust side complete. Intake side tomorrow. Taking my time and triple checking everything.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
when i had my tank off, i put more reflective heat barrier on front of tank, the header puts out alot of heat... as well as i covered rubber hose to left of header with heat shield material., another good thing is where seat sits, i cleaned and covered entire area with strips of the clear gorilla duct tape... its almost identical to 3M that you put on front of cars.... it will stop that gray crap that appears aftyer a ride running dwm side of tunnel, its also good for any where hood rubs.... since its clear you cant see it.
DMCTurbo
- Nov 12, 2005
Intake side completed today. New boost controller installed along with TD silicone charge tubes.
Mr.srx
What torque spec did you use for your head studs? Nice build
DMCTurbo
- Nov 12, 2005
65What torque spec did you use for your head studs? Nice build
RAMSOMAIR
More info on this please??when i had my tank off, i put more reflective heat barrier on front of tank, the header puts out alot of heat... as well as i covered rubber hose to left of header with heat shield material., another good thing is where seat sits, i cleaned and covered entire area with strips of the clear gorilla duct tape... its almost identical to 3M that you put on front of cars.... it will stop that gray crap that appears aftyer a ride running dwm side of tunnel, its also good for any where hood rubs.... since its clear you cant see it.
