Camo Grizzly 700
- Oct 13, 2007
My 07 700 Grizz likes to stall after i let off the throttle. It will restart with no problem, but seems to be getting worse. The dealer can't figure it out. Anyone else have this issue?
pat the rat
yep,mine does the same thing,i think they all do it from what i hear on other forums.i noticed that it only stalls when i take off really easy,if i give it more gas its ok
Camo Grizzly 700
- Oct 13, 2007
have you had your checked out? its a pain when you're knee deep in mud and you gotta restart the thing.
it stalls from the steam or does it stall under throttle??
Camo Grizzly 700
- Oct 13, 2007
stalls at idle or between shifting..... not when wet. hot or cold, doesn't matter.
I had this happen on my Road Star Warrior when it was really new, it just took some hard riding and it actually went away... you can also make sure the idle is set to spec... it might be too low.
yamahauler
my grizz has the exact same problem. it actually happened a few times in the bush on the weekend. it starts to get fustrating after a while
Camo Grizzly 700
- Oct 13, 2007
Any fixes? i do ride hard, it doesn't seem to mattter. my wife's FZ6 needed a TPS, and that still hesitates..... Maybe Yama's fuel injection is the issue? Other than this, LUV MY GRIZZ
maybe its the TPS, after a few miles on the Warrior it quit and runs awesome but I also zeroed the TPS with my PC3 fuel controller... I would contact your dealer and ask WTF.
pat the rat
mine only does it when its been warmed up good,might be related with the gas boiling issue,mine doesnt boil but you can hear pressure coming from the gas cap when you shut it off after a long ride,besides that it is one awesome bike
Camo Grizzly 700
- Oct 13, 2007
thanx for the help. dropped it off today at the dealer (again), i will call them and tell em to check the TPS and fuel control. they've played with the idle, and nothing. They've leaned it out, richened it back up, and nothing changes. have not had any boiling issues or "hot" gas problem. fuel seems to be fine. it did overheat once, but that's it. this rig kicks #*$&@ anywhere i take it.
please post any results from dealer!!!
Camo Grizzly 700
- Oct 13, 2007
just heard from the dealer. they say bad throttle body. will let you know when i get it back. as for over heating, it had too much mud on the radiator!!! Ooops.
Camo Grizzly 700
- Oct 13, 2007
just git the Grizz back from the dealer yesterday. They put an 08 throttle body on. Am going to ride today. So far, so good while riding around the yard. Will let you know when i get back.
Camo Grizzly 700
- Oct 13, 2007
still stalling . dropped it back off yesterday,will let you know soon,i hope
