Arctic_Sheep
- Jan 5, 2020
- Svalbard
- Norway
- Yamaha Venture RS 2008
Hi,
I'm a proud new owner of a 2008 Venture RS - and of course now that I tried to kick off the season, it wouldnt start. The former owner told me to squirt some gasoline into the fuel intake (see picture). I havent tried that yet, but I was wondering about that fuel line vent trick I read about here in the forum. Could somebody point out where to find that vent line? The owners manual doesnt really say...
Roger
- Feb 10, 2007
- Osgoode Ontario Canada
- 2012 RS Venture GT (power steering doesn't work when real cold)
2006 Indy 500
The vent trick works great.
It's been many years since I had the carbed Venture.
I believe it's under the hood, in front of your left knee. just unhook it, blow in it, hard, with your lungs, not an air compressor.
Then plug the hose with your tongue or thumb.
Start it!
Start it!
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
I’ve never had much luck with the vent line pressurizing but have had very good success using a spray bottle&after removing the airbox lid spray fresh fuel in all of the carb throats&it should take right offHi,
Metallicat
here!
nullptr
At the start of the season I had to hit my 2008 Vector LTX with a blast of starting fluid in the air box. Started right up after that, after a bit of an erratic idle it settled right down and has been easy to start ever since.
yank
- Jan 3, 2006
- Cook,MN
- 2005 rs venture
2006 rs rage
1971 elan
I pop of one of the fuel lines leading to the carbs and pour about a third of a cup of gas in with a small funnel to fill the bowls. pops right off after that. The large vent tubes on these carbs tend to dry out the bowls pretty fast. I necked mine down to 1/8".
