Steering Play due to Bellcrank
ksiesel
Columbus, Indiana
2015 Viper RTX-DX with QS3’s, winder jackshaft, RR front arm shaft, 4 wheel kit, and many more upgrades
LOCATION
Columbus, Indiana
My Viper has more steering play than I’d like and I’ve torn it down to the point where I’m confident that the play is in the bellcrank assembly. I’ve searched for other threads on this site about it and I’m pretty much coming up empty with any improvements for it. This play is not from the common heim joint loosening that so many have experienced.
Do any of you know of any updates, adjustments, or aftermarket options for this bellcrank play?
Check your A-arm mounting bolts for tightness. I had a loose one and it made the steering sloppy. Hopefully the bell crank flanfe hole hasn't worn oval.
