grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
I just did a steering shaft relocate similar to what OFT offers. I was interested in purchasing the OFT kit but didn't want to spend that kind of money yet so I designed a simpler, relatively inexpensive kit. My relocation mod doesn't move the handle bars as far forward as the OFT kit but still makes a huge difference in handling and comfort. I was amazed how moving the bars forward a few inches gave the handle bars a more natural motion. My original intentions was to design and install a temporary modification to see if the OFT relocate would be worth the investment but my mod worked out better than I expected. It relocates the steering shaft about half of what the OFT kit does and it reuses the OEM bushings but you still get similar results. I highly recommend doing a steering relocation with the OFT kit or as I did. This should be the first mod on your list, it really makes a difference. If anyone wants more details PM me.
FX Nytro steering relocate pictures by grizztracks - Photobucket
http://s589.photobucket.com/albums/ss33 ... 0relocate/
Version 2
Version 2
GT03235
Does it not put the steering shaft out of line for the bottom bearing with only a small shim?
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
after moving the top I took a measurement at the bottom and all that was required was a 3/16" shim. I also loosened the steering loop and repositioned it slightly to make up for the small angle change. The steering doesn't bind at all and I didn't have to reset the ski alignment.
Relocating the steering shaft is one of the biggest improvements I've made to the Nytro. If you haven't done this yet put it at the top of your mod list. Get the OFT kit or try what I did, either way you'll be amazed how well it improves handling and comfort.
Nytroglycerin
Good idea
. I know what i'm doing on friday night
. I'm pretty short so i'm kinda hesitant to order the oft kit, but this looks like it will be perfect.
mytro
Looks good, what was the pitch between original hole and new one? 1"?
Edit: I see it in your other pics.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Damn! Another mod for me to try? Hmmm, I think so.
A few questions:
- any trimming of the upper steering column cowl to accommodate the more forward steering column? Would it help to do so?
- did you have to bend the lower steering bushing bolts like the OFT relocator?
- did you lengthen the lower steering shaft using the tie rod nuts?
- how did you do the reroute of the gas vent line? Did it reduce gas leakage when overfilling?
- do your handguards now hit your windshield?
A few questions:
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
That's why I have been calling the OFT steering relocator as #1 modification for a Nytro. I could not get comfortable on my XTX until this change. Well worth it, and highly recommended!
snownutz
The Oft kit is way worth the money since besides the relocater you get the oilite bushings.
yamahabandit
Another mod, that compliments the steering relocate is the speedo relocate. If your in anyway vertically challenged like I am, it's a must have.. LOL
nytrose
I think I asked this question before but didnt get an answer. This mod looks great,is it still a comfortable and great handling mod to the bars if you are not a stand up rider.
yamahabandit
Absolutely! I stand/sit about 50/50 and I"m only 5' 8" and have no issues with the mod when I sit. It really is a different sled now.nytrose said:I think I asked this question before but didnt get an answer. This mod looks great,is it still a comfortable and great handling mod to the bars if you are not a stand up rider.![]()
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Grimm said:Damn! Another mod for me to try? Hmmm, I think so.
A few questions:
This is a simple mod. To install the upper relocate plates two holes need to be drilled in the existing steering mount. I used the center hole in the bolt plate to locate and drill the new holes. I did not need to reroute the cables, do any trimming, bending or steering realignment. The steering block is moved approximately 1" forward which makes standing easier and improves comfort and handling while sitting. I'm 5'8" and the bars are now positioned much better for standing or sitting. While sitting I've noticed I'm using the outer hooked portion of the bars more which gives me better control on tight trails.
The gas vent line (black fuel hose looping over the steering column) was added after I installed the trail tank. Every time I filled the 10 gallon tank it pushed a considerable amount of fuel out the line so I lengthened it and routed it up around the steering column to solve the problem.
If anyone is interested in this mod and needs more info on how to do it PM me.
NIce job, Grizz. I did a similar mod to my FX Nytro. If you don't mind, I'll throw the info in your post?
GT03235
Thankyou for giving me this idea, completed it last night cost me less than $5 with parts from lowes
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Grizz, I see that instead of installing 2 plates for the upper, you fabricated a one piece solution, rounded in a hoop style. I was thinking of this after you sent me the info...is it sturdier?
