Chartzy
- Feb 6, 2022
- Kerrobert
- 2016 viper MTX LE
Hello everyone, I have a 16 viper mtx LE with mpi turbo kit. Looking to loose some weight and drop the large trail can that’s on it. My dealer can’t get any holds on mufflers that fit the kit after mpi supposedly sold out? So I’m considering making a straight pipe for it, 2.5” pipe with a bend and weld the flange on. My question is will this hurt it in any way or screw up air/fuel ratios in any way? I would assume the less restriction after the turbo the better, but I want to confirm before I go ahead and do something that could cause it to run lean!
Thanks everyone!
Thanks everyone!
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
You will probably experience over boosting because the straight pipe has less restriction and therefore less back pressure on the turbo... More boost will be what affects the AFR, not simply the less restriction.
Other than that, your ears ringing will be what hurts.
Argo
- Dec 18, 2015
- central wis.
- 2015 Ltx le
I have extra flanges that I had made if you want to try make a custom pipe or I would sell my Areo Pipe.
Chartzy
- Feb 6, 2022
- Kerrobert
- 2016 viper MTX LE
How much would you like for a flange or for the aero pipe? And have you noticed any changes for boost and afr? ThanksI have extra flanges that I had made if you want to try make a custom pipe or I would sell my Areo Pipe.
Argo
- Dec 18, 2015
- central wis.
- 2015 Ltx le
I had to add weight to stay off the rev limiter. I spoke with Ulmer after I installed it and changed some Gems settings also. Added about 10 hp. I baught it last year and would let it go for 200. I'll throw in the flanges I had made also.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
I have a hindle that I took off my Viper which is pretty much straight through if your interested. Not sure if it fits the same though as I am not boosted.
turboviper815
- Jan 4, 2024
- Quebec
- 2015 sr viper rtx 1.7 mpi turbo
Have anything still laying around ?I have extra flanges that I had made if you want to try make a custom pipe or I would sell my Areo Pipe.
