Does anyone have any tips on removing stripped Allen key or torx hole in the stud? The steel nut is rusted really good and the stud just spins.
I have had luck drilling out the aluminum nuts, but the bit just won't drill the steel. I'm not looking to keep the stud or nut but would like to keep the single backer.
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
I would spin the track so the problem area is towards the rear, or an accessible spot. I would then cut the nut with a cutoff wheel. Or try to grip the head of the stud with vice-grips, then spin the nut off
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
X2 for the cut off wheel
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Cut through the nut with a 4” grinder and cutoff wheel, then I use a coarse flap wheel to sand the Nut down even thinner. Usually you can then spin the Nut off with an impact without even using an Allen wrench. There won’t be much Nut left is all.
On the aluminum nuts, I drilled a couple small holes on one side, just until I contacted the stud, so I could split it open and then was able to unscew it.
The ones with steel nuts, we're a little more difficult. I used the suggestions and sacrificed the stud to save the backer. A Zipcut wheel to slice the side of the nut off. Then with it "relieved", most were able to unscrew with a wrench and vise-grips holding the stud. Some required a 2nd relief cut as they were being extra stubborn.
