justin1620
- Feb 3, 2014
- Rainy Lake, Ontario
- Sidewinder
- www.rustymyers.com
hey fellas, is it necessary to have a 4th wheel kit if I stud the outside windows of the track? Looking at a 144 pattern with either 4,2,4 or 3,3,3 pattern studding the outside windows as well.....thanks
orangecrush
- Oct 23, 2012
- 2017 Yamaha Sidewinder LTX LE
- Lino Lakes, MN
I ran 192 with stock wheels last year and was fine but have added the JT 4th wheel kit for better traction this year.
WinterWolf
- Mar 25, 2017
- Connecticut
Good idea, especially if your studding to have 4 wheels across the back! Studs put more pressure on that rear axle, and with just the two wheels back there, there is a tendency for the sled to Cat walk on agressive acceleration when studded.
Put a 4th wheel kit on both my 06 Mach Z and my Apex, because those two sleds didn't come with 4 wheels(they had 3 wheels..Sidewinder which has significantly more power than both of those sleds, only has two wheels). If I were you I'd get at least a 4th wheel kit, if not the J&T Stealth big wheel kit.
I have a 50th anniversary that I'm studding, and I got the J&T Stealth kit for mine..not taking any chances with the tri hub junk. But that's just me.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Four wheels really eases the pressure on the bearings and allow them to last longer
It goes without saying- 2 are doing twice the work as 4
When I upgraded my nytro I couldn't believe how well the bearings stood up with 4 vs 3 wheels
Ms
Ms
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
First of all, if one wheel or bearing goes, you are SCREWED! Secondly, have you seen the stock design? I think it's a 10-32 screw back there
orangecrush
- Oct 23, 2012
- Lino Lakes, MN
I will suggest that you just put the 192 in this sled. I started with 144 down the middle and not enough, just spins. Added more to make it 192 going on the outside and much better holeshot and traction in corners. This sled just has too much horsepower to run it like a normal sled. I ride trails and lakes in Northern Wi, so depends on where you ride.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Add the outside wheels!
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
The four wheels are a must for security and performance....and enough and long enough studs...
Finesy
- Apr 18, 2017
- Manitouwadge
- 2018 Sidewinder RTX 50th Anniversary
2017 Sidewinder LTX SE
4th wheel kits and studs on both of mine
