tedgoesfast
IH8CROWS
You went up the middle....
Hope it's got the loop on the skid.
https://ty4stroke.com/threads/studs-in-the-middle.81981/
tedgoesfast
Put 8500 miles on my 05 rx1 studded that way never had an issue when I get it on I will check thanks
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
If it is a 2011 or newer, especially a shorty, you may need to remove some in the centre.
Not a lot of room to start with & then there is the Exup.
Year & stud length?
Year & stud length?
tedgoesfast
07 shorty its what woody recommended
tedgoesfast
There is only three eights over lug on a one two five ripsaw
Riceburner
- Apr 14, 2003
- N.B. Canada eh
1.325's ?
If so, should be fineon an 07 although I never studded the centre inch as studs there can wear the shock . Ulmer I believe used to sell a kit to protect the Mono if you studded the centre.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I am thinking of 1.4s in my xtx , 3 per bar, any one have concerns there?
I will remember to stay away from the shock in the center. Have the same 1.4s on my 121 and 136 Vectors as well as had them on my 06 Apex.
Any issues with these studs on a 2013 Apex XTX 144 tip up?
Riceburner
- Apr 14, 2003
- N.B. Canada eh
No issues.
yamadoo
- Jun 3, 2003
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
make sure you reinforce the tunnel protectors the bracket that holds them is C shaped and collapses when the track hits them there are threads on the subject and port Yamaha has a kit to fix it but most people could fix it themselves with a little ingenuity.I am thinking of 1.4s in my xtx , 3 per bar, any one have concerns there?
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
1.325's ?
I remember putting that kit on my '07GT. It was literally two bearings to go on either side of the shock mount, and a longer bolt. Ingenious kit, and it worked. When the skid went in for the beef up kit, they also put a loop of short pipe welded on to give a wear point as well and protect the loop on the shock. This was all after I had HyGear rebuild the mono with a new shaft and loop. Studs up the middle did some damage, that's for sure.
yamadoo
- Jun 3, 2003
Thanks will do
