Allan
Trying to get a little more rear transfer out of my STX DX 146 and make suspension softer.
My sled seem to have heavy rear spring little or no sag in sled .
-Transfer blocks set on 1 ( can’t take them out suspension well hit wheels )
-centre spring shock spring tighten up some ( can turn by hand when rear of sled is off ground )
-spring set on lowest level
But suspension is still stiff in read.
I know I could change the spring but trying to do it without doing that.
The front plastic mount where the spring is attached to suspension on mine in about an 1” bigger than the ones on the LTX and RTX
So I was going to get the plastic mount from the LTX and put them on my suspension. There only about $5 each.
This would make the spring less compressed.
As it is now I can stand on back of sled and suspension don’t touch transfer blocks.
Do you think this would help?
Allan
By me switching to the small blocks I can reduce the pressure on the spring by 1" .
YamaSpark
- Sep 21, 2017
- Greenfield, Minnesota
- 2016 SR VIPER S-TX 137 DX
I'll be watching this thread with great interest because the rear suspension on my 2016 STX 137 DX also seems to be too stiff.
Although, it probably doesn't help that I weigh 160 lbs. soaking wet....
Aren't the DX models supposed to be more plush?
They are supposed to be. You guys have the overload leaf stock right?I'll be watching this thread with great interest because the rear suspension on my 2016 STX 137 DX also seems to be too stiff.
Allan
No there not stock, but I did buy them. there not engaged on less I want them to be. The spring in back is heavy on mine because of the extra weight I can carry. Also got 2 up seat for it, then I use the over load springs.
Mine ride good just stiff in back end, hard to get it to bottom out on back. Like I said if I stand right at the end of sled I cant get the sled to bottom or touch transfer blocks with spring set at it weakest setting.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Does that dx style spring holder relax spring tension? Moreso than an ltx holder.
Allan
Yes it does it had 3 settings. mine is in it lowest . that why I was going to get the smaller slide blocks like I showed in picture so it would further reduce the spring tension.Does that dx style spring holder relax spring tension? Moreso than an ltx holder.
Doc Harley
- Oct 17, 2016
- Here & there
I'm sorry Allen. Please forgive me. I figured the shorter slide block would create less tension?
Allan
Sorry maybe I didn't explain it clearly. But Yes your right the shorter slide block well also create less tension on the spring. There is also a rotating block with 3 setting on the short end of the spring. I'm all ready at the lowest setting on the short end of spring with the rotating block .I'm sorry Allen. Please forgive me. I figured the shorter slide block would create less tension?
So to get less TensionI was going to go with the shorter sliding block.
Doc Harley
- Oct 17, 2016
- Here & there
Hmm. Ok. Was trying to soften the blow back there myself. Replacement springs are $165.us. seeing if there's another way is all.
Also, I'm assuming Yamaha sells one spring for all models then changes out the slide blocks?
Thank you.
Allan
Your Ltx all ready have the shorter blocks.Hmm. Ok. Was trying to soften the blow back there myself. Replacement springs are $165.us. seeing if there's another way is all.
Thank you.
Maybe you can turn them over? Don't if this well work but looks like it well.
Doc Harley
- Oct 17, 2016
- Here & there
Yep.....hygear sells replacement torsions. Just wanted to exhaust more inexpensive options.
Cheers!
YamaSpark
- Sep 21, 2017
No overload leaf on mine.They are supposed to be. You guys have the overload leaf stock right?
Cannondale27; didn't you experiment with lighter torsion springs from Cat? Did you find a set that made a noticeable difference?
Allan
You can only get the over load spring for the stx dx 146
Isnt that what these guys have? I am thinking they deleted it on there sleds. Maybe compensating with a heavier Torsion spring. Take a look at the Cat side. Pantera. All guys I know that have them say they ride awesome. They also have the overload.You can only get the over load spring for the stx dx 146
