fourbarrel
Building a collection one sled at a time
- Sep 23, 2004
- New Brunswick
- 2019 SRX
I'll preface this thread by saying yes I have the owners and service manuals and know what the recommended method of summer storage is as far as gas goes. What I'd like to know is has anyone drained their tank and run the sled dry for long term storage? I've always had great luck doing this with my 2 stroke SRXs snd have never had any buildup in the carbs or tank. Even with stabilizer I just don't have a lot of faith in the gas these days and figured draining the system would be better. I did use stabilizer last spring and then drained as much gas out in the fall as I could before filling with fresh supreme but I am just curious if anyone has drained their sled and how it worked.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Draining it completely exposes everything to oxygen, oxygen is a corrosive. You can't get all the gas out of the system without disconnecting hoses, blowing out injectors, etc so what you are doing is potentially exposing what gas remains to oxygen which turns it into varnish. Whereas leaving treated gas in the tank will act as a buffer for heat cycles, limit condensation build up, and keep all the components wet.
stgdz
- Mar 27, 2021
- Buffalo MN
I have typically leave a full tank in my sleds with k100mg.
I was told that keeping the pickup tube in the air(sidewinder doesn't have this) would end up hardening it.
Carbide
- Apr 20, 2017
- Elk River, Minnesota
- '15 Apex X-TX -SOLD
'21 Sidewinder L-TX SE
- Minnesota
Full tank of non oxy with Seafoam hasn't failed me over 5 decades of storing dozens of different seasonal toys.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Last 2 off seasons I’ve been taking my tank off my 20 for service/inspection/cleaning and emptying the fuel out and will be doing it again in next couple weeks but I’ve never ran the sled till it ran out of fuel. So far I’ve hadn’t had an issue.
IMO tank should be removed early on these sleds, rivets under header, tunnel and exhaust inspection are good things to look over before the start of the next season.
store all my sleds full of supreme with seafoam. no issues yet. also doubles as an emergency gas stash for summer power outages.
fourbarrel
- Sep 23, 2004
- New Brunswick
- 2019 SRX
I have read that about the rivets in the tunnel under the tank and I plan to strip mine off this summer or fall to check them.Last 2 off seasons I’ve been taking my tank off my 20 for service/inspection/cleaning and emptying the fuel out and will be doing it again in next couple weeks but I’ve never ran the sled till it ran out of fuel. So far I’ve hadn’t had an issue.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Yes they need to be checked, we all know the rivets are very low quality, issue is they start to vibrate and wear into the aluminum. All 4 of mine were loose and the 2 outside one’s being the worst, just replace with higher quality rivets or SS bolts and locking nuts.I have read that about the rivets in the tunnel under the tank and I plan to strip mine off this summer or fall to check them.
fourbarrel
- Sep 23, 2004
- New Brunswick
- 2019 SRX
I bought a box of Staves multi grip rivets a few years ago to do the chassis on my '98 SRX so I have plenty of them left,as long as the ones in the Winder are 3/16" ?I have read that about the rivets in the tunnel under the tank and I plan to strip mine off this summer or fall to check them.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Yes 3/16” will workI bought a box of Staves multi grip rivets a few years ago to do the chassis on my '98 SRX so I have plenty of them left,as long as the ones in the Winder are 3/16" ?
fourbarrel
- Sep 23, 2004
- New Brunswick
- 2019 SRX
Perfect.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Fill all my toys with high test for storage never had an issue.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I just leave whatever was in them at the end of the season until the beginning of the next. Then, I siphon it all out and put fresh in before firing them up for the first time at the beginning of the season.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Yep, whatever comes out goes in the lawnmower or something else I care less about.I just leave whatever was in them at the end of the season until the beginning of the next. Then, I siphon it all out and put fresh in before firing them up for the first time at the beginning of the season.
WindTime
- Feb 14, 2022
- bracebridge
- 2018 yamaha sidewinder
sea foam works is amazing for storage where regular stabilizer can gel in the tank if left long enough and not properly mixed before storage. I always use seafoam and start once a month during storage never had an issue.
- 6K
