Woody255
Hi all,
I have an Apex built for snow drags with an MPI s/c, stage 2...2 1/2. Running 18-19psi at 10,400 on pure C14+. PC5 with Autotune, POD300 data logger etc. This was built a few years ago and has dominated the local snow drags. At the end of the season, I began having a few issues with the throttle bodies coming lose, as I did not have them tethered down securely. That has been resolved, and all was good. At the last heat of the day, I could only run up to 9000rpm, and I still cannot figure out why. No abnormal noise, both S/c belts are good, throttle bodies secure etc. AFR readings are proper, clutches look fine...any ideas out there? Thanks. Woody
gouldsjett1
Check your boost tube connections from the s/c to the front of the intercooler.
kinger
Have you changed anything in the clutch recently?
Woody255
No, haven’t changed anything. It was working great, and the very next pass it wouldn’t pull the rpm.
how heat soaked was the sled? where clutches hot?
I would do a leak down test. Don’t sound good. How much boost?
kinger
Have you checked the throttle blades are opening fully at WOT?
Woody255
It did not get hot. Engine runs perfectly, just simply won’t climb to full rpm. My first though was a SC belt failure, but they are ok....I will do a compression test to be sure, but I do not think it’s an engine problem.
Mr.Sled, 19psi
Mr.Sled, 19psi
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
Does it rev / pull hard right to 9000 rpm then flat-line?
Same with boost? Jumps up then flat-lines? If so, maybe if your SC has an internal sprag type clutch it might be that it's now junk / slipping when reaches a given boost level... Seen that happen on certain model MPI SC's (aren't repairable), and have that happening right now on a SC Wave Runner.
Woody255
Yes, that’s what’s happening. All seems well until I run 100% throttle. Happen to have any photos ? Thanks
Check for boost leaks
Woody255
Update here...found the vacuum line coming off the BOV was severely cracked. Fixed the hose, problem solved.
Nice!!! at least it was inexpensive!
- Apr 14, 2003
- Hessel, Michigan
Awesome!
