mp5
- Feb 14, 2011
- New Brunswick, Canada
- 09 Nytro XTX
Just scored a sweet pair of Superclamp ll's. However, po did not have the E Track system. Has anyone here ever used the SC's and just screwed a hole in the trailer deck, installed the bolt and anchor it with the washer and nut?
Im a bit worried it may pull through unless I attach a bracket plate underneath (which I'll do), or buy a set of e tracks to spread the pressure out...and give me more attachment points
I have. Added Big fender washers and made sure on the under side had either trailer rib to tie into or add a flat plate to bolt thru.
mp5
- Feb 14, 2011
- 09 Nytro XTX
No issues eh? SC's work well?
Do the plastic "keys" stay in place when ur moving down the road, after you've turned them down?
No issues and yes, the keys stay locked in nicely. I have never had one pop out. Been running those clamps for the past 3 years.
mp5
- Feb 14, 2011
- 09 Nytro XTX
Peter A
- Jan 29, 2010
- Long Sault, Ontario
- 2016 SRViper LTX-DX
My Toy Carrier trailer does not have a track system in the floor either. The hold downs are drilled through the floor with large washers on both sides. No problems in 6 years.
wexfordhunter
- Feb 8, 2009
- Clawson, MI
- 2008 Apex LTX GT
2004 ViperS
- Clawson, MI
When I used them I attached lock keys to clamp with a loop of small coated cable. When you undo them keys stay safely attached.
