Nytro6211
- Feb 11, 2012
- Winnipeg,MB
- 09 Nytro,Hindle Hurricane power up kit,Supertips,Tracks USA 136,1.5 Intense
I have a Nytro with the Hurricane Hindle upgrade and am running a 136 Intense. I need a starting point to set up my Supertips. Any help would be appreciated
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Contact Allen Ulmer he's a sponsor for this site plus he's the guru on Supertips I believe. Ulmer Racing in the preferred vendors section.
Nytro6211
- Feb 11, 2012
- Winnipeg,MB
I emailed him and waiting for a replyContact Allen Ulmer he's a sponsor for this site plus he's the guru on Supertips I believe. Ulmer Racing in the preferred vendors section.
devilnabludress
- Aug 30, 2013
- Eastern Ontario
- 2011 Nytro XTX
I'm running 4 washers on the heel, one on the tip. Full Hindle, Hurricane Kit. Dave used my sled as the test sled to develop the Nytro clutch kit.
johnelway
altitude?
weight of you on the sled?
Nytro6211
- Feb 11, 2012
- Winnipeg,MB
Mostly running trails in Manitoba,Canada. 2000 ft or so. About 210lbs all geared upaltitude?
johnelway
ok and your sled is nytro xtx? 1.75 paddle?
Nytro6211
- Feb 11, 2012
- Winnipeg,MB
Nytro is a 136. 1.5 inch paddleok and your sled is nytro xtx? 1.75 paddle?
johnelway
okNytro is a 136. 1.5 inch paddle
i'm running same setup as you but 144 1.75" and my setup is
1 thungsten + 3 washer in heel only.
i need to move 1 or 2 washer from the heel to the tip cause i'm running too low at start and too high at top speed.
i'm 250 geared
Nytro6211
- Feb 11, 2012
- Winnipeg,MB
Thx for the info. Hope to try it this weekend if I can find enough snowok
i'm 250 geared
johnelway
just come in Qc, we have enough snow for everybody. ahahahThx for the info. Hope to try it this weekend if I can find enough snow
Good luck!
devilnabludress
- Aug 30, 2013
- Eastern Ontario
- 2011 Nytro XTX
520 feet above sea level, 236 lbs ready to ridealtitude?
johnelway
finally made some test yesterday,
1 thungsten + 1 washer in the heel
1 washer in the tip
seems realy good trail setup.
maybe i will remove the other washer to keep only the thingsten in the heel.
will be similar to you.
i'm running at around 500-2000 feet.
1 washer in the tip
Nytro6211
- Feb 11, 2012
- Winnipeg,MB
Thanks for the good info. Ride safe!finally made some test yesterday,
1 washer in the tip
johnelway
what rpm do you get when hitting the throttle at wot?
8500 then goes down to 8200 and going up to 9100 at full speed on my side.
