tbarile
- Dec 21, 2010
Was going to replace the rear bogey wheel and noticed part of the suspension broke. Is that the dreaded w arm I’ve read about? I’m trying to take the suspension out but having problem. I removed the 2 front nuts in the footwell and the front dropped. I then removed the 4 (2 on each side) rear nuts located in the footwell but the rear is still stuck in place. Am I missing something?
tbarile
- Dec 21, 2010
Disregard. You guys probably knew this but the bolts in the footwell do not detach the suspension. Removed the 2 bolts under the footwell and she dropped out.
Fast Lane
- Feb 6, 2020
- Winnipeg
- 2007 Yamaha Nytro ER
- Winnipeg
Send the shocks out to get rebuilt and revalved while you have the skid out. See if Hygear makes torsion spring spacers. Both of these updates made my sled so much more comfortable to ride.
Metallicat
That is the mono, no torsion springs. A revalve on a stock mono can do wonders for ride quality, depending on model year. If that is a pre 2008 mono, then see about a front arm from Barn of Parts, 2008+ models were reinforcedSend the shocks out to get rebuilt and revalved while you have the skid out. See if Hygear makes torsion spring spacers. Both of these updates made my sled so much more comfortable to ride.
