wacnstac
Can someone post the technique to flip this block back and forth. I struggle to do so with my hands. The manual says something about a tool. What does the tool look like? Can I substitute something else?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I think you're supposed to do it with a wrench. I've flipped mine up and has been there since forever. The owners manual should explain it.
trail traveler
- Dec 3, 2014
- Everett, WA
- 2015 sr viper s-tx-dx
2014 Venture MP
2016 RS Venture
2017 sr viper x-tx
3- 1990's era Arctic Cat prowlers
Google Phazer / Venture Lite It is a PDF file. Page 37 of this file has an illustration that should help a bit.
YukonMP
- Dec 25, 2014
- Yukon Territory
I think you will find a tool in your kit that looks like a spark plug wrench(maybe it is a spark plug wrench come to think of it). Anyway the white block has a hex receptacle that the socket fits into. Like Mooseman, mine is in permanent 2up. If I remember correctly the same tool fits the rear suspension adjuster also. Your manual makes other helpful and obvious suggestions like making sure you do both sides. I think they only put that in for old people who are really losing it ... like me.
YukonMP
- Dec 25, 2014
- Yukon Territory
Hey Trail Traveller, how the hell did you do that? Apparently I have a copy of my manual on my computor now so I can just leave my print copy in the outhouse.
Thanks!
Thanks!
wacnstac
Thanks for posting that page from the manual. Makes me wonder if a regular socket of the correct size will work as well.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
I think you need the actual tool. IIRC, it's a hole in the form of a hex.
trail traveler
- Dec 3, 2014
- Everett, WA
2014 Venture MP
2016 RS Venture
2017 sr viper x-tx
Sweet! The short answer would be, internet search then copy and paste that info here. Hope that is helpful. If you "bookmark" that link, that info will always be one click away for future reference.Hey Trail Traveller, how the hell did you do that? Apparently I have a copy of my manual on my computor now so I can just leave my print copy in the outhouse.
Thanks!
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
I always download and save a copy because things tend to disappear on the Net.
BACK COUNTRY YAMAHA
- Nov 26, 2015
- newfoundland
- 1997 vmax 600 sx, 99 venture 600, 2004 vk 540, 2006 Yamaha vk pro, 2009 venture multi purpose and 2006 venture 500 xl current ride 15 rs viking pro
I don't even bother with the tool, just pull the spring up and rest it on the idler wheel and flip up block and place the spring on the two up block and it's done! No tools required! Cheers!
wacnstac
That's what I ended up doing. Seems like the easiest way.I don't even bother with the tool, just pull the spring up and rest it on the idler wheel and flip up block and place the spring on the two up block and it's done! No tools required! Cheers!
