taylor lemke
- Jan 18, 2017
- Minnesota
- 2008 yamaha nytro stage 1 MPI Super charger with intercooler
does anyone know where I can get a taper lock to fit a 28t pulley. the 22t wouldn't fit.
Zuki1216
- Dec 9, 2015
- Indiana
- 08' Apex LTX
07' Attak MPI S/C
Are both of your Pulleys aluminum or steel?
Sent from my SM-N910V using Tapatalk
Contact MPI, they would have them.
taylor lemke
- Jan 18, 2017
- Minnesota
both pulleys are aluminum.Are both of your Pulleys aluminum or steel?
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
if you google GATES taper lock pulley you can find a page with the part numbers and order from most any autoparts stores....
Here is a pick of the actual pulley I got a friend of mine. I s0ld it to him for $113 CDN.
I forget all the details and the part number...but 1108 and 20mm (width) are important....
here's a page to look at.
http://partview.gates.com/catalog3/d/gates.pt/?c=products&cid=gt_metal&id=P24-8MGT-20
I am in need of a bottom pulley. Any idea where to get one that will fit? The taper lock is reverse on the bottom from what the top is.
