hmmrdwn
- Jan 7, 2018
- 2018 Yamaha Sidewinder LTX-SE
Turbo Dynamics
2017 2019 Sidewinder SRX Belt Adjuster With Float
When installing this i was told to remove the shim behind the secondary because the clutch will now float. Once it is tightened up there is no movement in and out on the shaft. no float. Am i doing something wrong? i dont want to blow belts. stock setup offset was perfect. no belt issues or abnormal wearing.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Once your secondary starts to open you will begin to have float.
You need to install 2 flat washers between bolt and spacer.When installing this i was told to remove the shim behind the secondary because the clutch will now float. Once it is tightened up there is no movement in and out on the shaft. no float. Am i doing something wrong? i dont want to blow belts. stock setup offset was perfect. no belt issues or abnormal wearing.
hmmrdwn
- Jan 7, 2018
no this replaces the spacer and 2 washers.
hmmrdwn
- Jan 7, 2018
Thanks DMCturbo. any idea how they accomplished this? i'm just curious.
- 31K
- 23K
- 20K
- 54K
