REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Do u have take the head off for head studs? Messing around with the valves and timing chain kinda scares me. I think I could do it with proper direction but I just don’t know how to
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Head doesn’t have to come off but I’d recommend pulling it and putting a better head gasket on while your at it
What's the better gasket?Head doesn’t have to come off but I’d recommend pulling it and putting a better head gasket on while your at it
I was watching one of Redneck Petes videos and they were using stock gasket.
Retainers wouldn't be a bad idea
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Dont they suggest valve springs too for the high rpm? Might as well take it off and do everything while your there.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
TD has a cometic gasket they recommend for high boost.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Ya all that stuff makes sense if yr pulling it apart anyway. Just intimidating bc I don’t wanna f something up
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I felt the same way when I built my stage 6. If you have mechanical ability it's really not that bad. I watched some SXS BLOG videos were they build a YXZ motor, made sure to have the shop manual for the torque sequences and specs. Buy the right tools and take your time.Ya all that stuff makes sense if yr pulling it apart anyway. Just intimidating bc I don’t wanna f something up
DMCTurbo
- Nov 12, 2005
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
For stage 6 ... we did commetic multi layer gasket, cam shafts, hd timing chain and manual tensioner, head studs, springs and anti flip cups, also did 3 angle valve job. and cleaned port match. these were min requiremnets you should do for stage 6 and/or big or mod turbo. since there was VERY LITTLE money spent this year on travel or sledding... might as well do the bigger turbo now. lol
Another person that takes no prisoners...For stage 6 ... we did commetic multi layer gasket, cam shafts, hd timing chain and manual tensioner, head studs, springs and anti flip cups, also did 3 angle valve job. and cleaned port match. these were min requiremnets you should do for stage 6 and/or big or mod turbo. since there was VERY LITTLE money spent this year on travel or sledding... might as well do the bigger turbo now. lol
DMCTurbo
- Nov 12, 2005
Probably the last day on the lake. Had to get out of this pass but she was on a mission. Looking forward to hopefully a real winter next year.
JLR
- Dec 6, 2006
- Winnipeg, Mb
- Currently, 2017 Arctic cat thundercat 2018 sidewinder xtx se 137 precision stage 4, 2025 Yamaha Srx bone stock
what gearing are you running with the big turbo
DMCTurbo
- Nov 12, 2005
Between 1.64 and 1.75 depending on conditions.what gearing are you running with the big turbo
- 24K
- 6K
