HUNT 24/7
- Mar 23, 2015
- N.B
- Nytro
You racing up on the head pond? I'm just outside Woodstock in Bedell.So after testing, it was the xs 825 bringing down rpm. Need to clutch significantly lighter for this belt. Me I will run the 8jp for this year and throw in the xs for our Sunday race your neighbors we do here. I ran the 8jp in 16” of fresh powder yesterday mostly on power trail and it was spinning 8800 in that so shoud be bang on when the groomers are done by Saturday night. The snow is FINALLY here in western NB and the groomers are out in full force
Winder_506
- Dec 21, 2012
- New Brunswick
- 2005 rx warrior
2013 apex xtx with woodys power up kit clutch work and mbrp pipe
It was on the head pond last year. Moving back to the field just below the head pond on the Wicklow side. Accessible still via the snowmobile trailYou racing up on the head pond? I'm just outside Woodstock in Bedell.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
8JP wont last with big power, not too mention you will be needing to clean tunnel and clutches often, that belt is by far the dirtiest/grimiest belt ever made!
Dan
Dan
Winder_506
- Dec 21, 2012
- New Brunswick
- 2005 rx warrior
I know it is but I’ve got 2 8jp belts and am about strapped after spending 25k on this sled this year. Wish there were more threads on here about clutching exclusively for the XS. The apex I’m coming off did not react this way. Hope my troubles helps someone else out on the clutching choices.8JP wont last with big power, not too mention you will be needing to clean tunnel and clutches often, that belt is by far the dirtiest/grimiest belt ever made!
Dan
