DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
What's everyone seeing for boost with the PT CAI tune?
I'm seeing 14.7 to 15.4, probably average is 15.1ish.
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
I got two new Jukebox packages for 3bar map, I haven't tried the Stock Mod muffler juke box yet, but with the 3" Sandale I'm seeing as high as 17psi on PowerTrail. Not sure if I should be concerned, no knock, but still. I'll try the Stock Mod muffler this weekend and see what I get.
DMCTurbo
- Nov 12, 2005
17? Wow seems high. I'm nowhere near that. The most I can get through my stock BOV is 15.4. Proved it today as I flashed max 17 and could only get 15.4, turned the BOV around and was seeing high 16s but seen knock and quickly aborted and swapped the BOV back around.I got two new Jukebox packages for 3bar map, I haven't tried the Stock Mod muffler juke box yet, but with the 3" Sandale I'm seeing as high as 17psi on PowerTrail. Not sure if I should be concerned, no knock, but still. I'll try the Stock Mod muffler this weekend and see what I get.
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Oh, I have the Turbosmart BOV. The jukebox tunes I got are for that and the 3bar. And yeah, 17 psi from PT has me puzzled.
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
not surprised at all that your seeing 17 on that map. 3" hyperflow flows very well, Turbo smart BOV does not leak. And your 3 bar sensor allowing you to read boost past the stock sensors limitations.
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
It's a strong running PT no doubt ;-)not surprised at all that your seeing 17 on that map. 3" hyperflow flows very well, Turbo smart BOV does not leak.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Mufflers come into play with boost....
My stock modded muffler flows a tad less...but still sick amts of pull and power, I like the quietness for sure.
I am more concerned with where the boost comes on. Its definitely an addiction!
Dan
Dan
ShootToThrill
Solid 16psi on my pt cai on a long pull 1500ft+
sledding rocks
for me pt 17.8 . max spool 17 18.9 , alls goodnot surprised at all that your seeing 17 on that map. 3" hyperflow flows very well, Turbo smart BOV does not leak. And your 3 bar sensor allowing you to read boost past the stock sensors limitations.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Ya,beerman,my guage reads same thing,and that is on evo 4 map which is 14.7-14.9 according to them,when I called them to ask,i told them I am seeing at least 2psi higher than what there tune was suppose to boost to. And maybe it is because of our 3" sandale mufflers,but I absolutely love mine,how do you like the sound and performance of your sandale?I got two new Jukebox packages for 3bar map, I haven't tried the Stock Mod muffler juke box yet, but with the 3" Sandale I'm seeing as high as 17psi on PowerTrail. Not sure if I should be concerned, no knock, but still. I'll try the Stock Mod muffler this weekend and see what I get.
DMCTurbo
- Nov 12, 2005
Really what exhaust r u running? That's impressive out of PT. what other hardware do u have?for me pt 17.8 . max spool 17 18.9 , alls good
sledding rocks
turbo force exhaust , ts bov , 3bar , td cai ,Really what exhaust r u running? That's impressive out of PT. what other hardware do u have?
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
I really like the Sandale Hyperflow. I’m not sure what it’s like around me when I’m riding, but I don’t think it’s too loud for me as the rider, and I don’t like a lot of noise. This is very subjective stuff, and after the dB test I was afraid it would drive me crazy, but I think it has a lower bass tone and less treble which makes it ok “for me”. Again pretty subjective, but it feels quieter than my stock Apex and no louder than the SQ, although the dB test tells a different story.Ya,beerman,my guage reads same thing,and that is on evo 4 map which is 14.7-14.9 according to them,when I called them to ask,i told them I am seeing at least 2psi higher than what there tune was suppose to boost to. And maybe it is because of our 3" sandale mufflers,but I absolutely love mine,how do you like the sound and performance of your sandale?
Having said that, I’m super impressed with the TD Stock Mod muffler. Power is very good and I can’t even hear the exhaust at 60 mph, just the wind and engine, it’s a totally different and pleasurable experience.
As for the performance of the Sandale Hyper-flow, picking up 2 psi just by adding it speaks for itself
Lusemeat924
- Jan 1, 2016
- Drumbo, Ontario
- 2018 Yamaha Sidewinder 137 XTX SE
I would be asking what gauges they are running maybe. There has been some aftermarket gauges showing false boost readings.
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
All my results are with the GAP data logger and 3bar MAP sensor.I would be asking what gauges they are running maybe. There has been some aftermarket gauges showing false boost readings.
