Extreme Tours
Would like to know what weight you guys are running in your heavyhitters
My team has a 54-36, I am running a 7/16 bolt at the tip, in the middle 7/16 bolt 5small brass and 1 steel washer.
my take off is 10400 and holds till 110 on dream meter then slowly drops to 10200-10300. top end 128-130 on dream meter with gps 115mph.
04 warrior with freddy's filters geared up one tooth.
silver carb springs
175 jets
screws at 2
stock primary clutch/spring eccept for weights
104 studs
I also have a black-green and a red-black for the team roller
not sure whats in the team now.
Any sugestions on how to get 200 more rpm up top?
should I use weights or springs.
THX
BILL
silver carb springs
175 jets
screws at 2
104 studs
THX
BILL
grauser
Lighten the tip. Use the 3/8 bolt.
Extreme Tours
how many washers would you use under the 3/8 bolt
grauser
Your post stated you had 7/16 with no washers. Try 3/8 with no washers.
grauser
just in the tip
Extreme Tours
the 7/16 bolt weighs 4.2 grams and the 3/8 bolts weighs 2.6 grams
do you not think that taking this much weight off the tip is a bit much for 200 rpm
- 226K
