This will have been done.i,m in the process of getting a 2016 rtx dx for a great price should i be( sceptical) it is new and will this update be allready done before pickup later this month ??
tnc110
- Jan 5, 2015
- Sidewinder BTX SE, SRXs
Huston
- Jan 19, 2017
- Zr 9000
Great job on this write up didn't know where to set the gear inside!!
Huston
- Jan 19, 2017
- Zr 9000
I am lost I put this back in after changing my gears on sidewinder and it seems like once I put plug in with gears pushed in I go to put actuator on and it's just a bit off and if I tourqe it to line bolt holes up the plug moves out of the grove?! Can someone help?
You are allowed to torque it that little bit. Most important final step is to start sled and go in and out of reverse 3 times before moving it. This sets home on the mechanism. Relax you are almost done buddy!I am lost I put this back in after changing my gears on sidewinder and it seems like once I put plug in with gears pushed in I go to put actuator on and it's just a bit off and if I tourqe it to line bolt holes up the plug moves out of the grove?! Can someone help?![]()
All Pics that PhotoBucket held hostage are now restored.
- 27K
